Old 01-14-2013, 07:46 AM   #1 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Eco- Headlamp bulbs?! anyone tried these?
Been looking for some bulbs to upgrade the candles on the 328i, and stumbled on these Philips bulbs.. what do we think? Has anyone used them?
H1 PHILIPS ECO VISION POWER SAVER | eBay
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 01-14-2013, 08:01 AM   #2 (permalink)
justme1969's Avatar
I found one blog from a suzuki test engineer says they work as advertised.
Old 01-14-2013, 08:07 AM   #3 (permalink)
Team m8
Interesting- do you have a link to the blog?
I'm probably going to be purchasing them this week- Failing that, the Osram night- breakers get a good name.
first and foremost is improving light output, then if I can get a reduction in consumption that'd be a bonus!
Old 01-14-2013, 02:08 PM   #4 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
.... if they still consume 55 watts, how are they using 20% less energy?
H1 lamp - Wikipedia, the free encyclopedia
Old 01-14-2013, 02:42 PM   #5 (permalink)
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
I measured current draw for the Sylvania ECO HB2 bulbs I put in my Civic.
Sylvania 9003/HB2/H4 EB EcoBright Headlight Bulb (Low/High Beam), (Pack of 2) : Amazon.com : Automotive
Funny, I don't seem to have written it down, but I remember thinking, "so it's actually 25% lower power than stock."
BUT, that was only for the low beam. For high beam, they were exactly the same.
I wish I could put HID or LED in there for some much larger power draw reduction, but alas, headlamp reflectors are designed for a very specific source geometry, as of now there isn't a way I know of to make the swap without changing the entire assembly.
The ECO headlamps still rank as the cheapest way to knock out ~20W, although I find swapping headlamps to be a surprising PITA. I'm still trying to find good LED's for the tail-lamps, so far I've had no luck finding 1157 LED bulbs that actually work in the Civic's sockets, at least not under $10/pair.
The Following User Says Thank You to christofoo For This Useful Post:
mcrews (01-15-2013)
Old 01-14-2013, 02:42 PM   #6 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
First Philips themselves say only 15% energy savings.
It appears that since they are 10% brighter than other bulbs at the same wattage, they produce more lumens per watt. I did some math... but it's probably wrong.
Old 01-14-2013, 03:26 PM   #7 (permalink)
Team m8
Good work on the thinking gents- be interesting to see the Maths behind it..
I'm after better "dipped beam" performance from the bulbs
Old 01-14-2013, 03:43 PM   #8 (permalink)
justme1969's Avatar
Wow looks like yall jumped way past my interjection. I was just searching by the name and mfg and it popped up the rating or approval could have been in amazon .com?
I did need to open about 7 pages to be satisfied with tech info gathered.
Sorry not much 4 ya to go on, ill start posting this kinda stuff from now on.
Old 01-15-2013, 01:31 AM   #9 (permalink)
Buddy - '94 Acura Integra GSR
90 day: 27.52 mpg (US)
If they are 10-20% less energy, what does that look like MPG wise?
- Aaron
Old 01-15-2013, 02:03 AM   #10 (permalink)
Hmmm the same rating as a standard bulb.
There are a few DOT approved passanger vehicle LED replacement head lamps. (I know of 1)
L.E.D conversion - EcoModder
