Old 11-03-2009, 04:00 PM   #1 (permalink)
Stickers - '91 Ford Tempo GL
Send a message via AIM to Hermie Send a message via MSN to Hermie Send a message via Yahoo to Hermie
Swirling vortices from vortex generators?
I ordered a set of the delta-shaped "Vortekz" generators thinking that it would smooth airflow on my back end, but after some tuft testing, it showed something I wasn't expecting at all.
I don't have a camera for pictures, but airflow was attached down the middle of the window all the way to the base, where the airflow apparently strikes the trunk surface fairly hard and causes it to move towards the sides of the trunk. Behind that, airflow looks smooth rearward.
On the sides of the window, I noticed rotational movement of the tufts giving the impression of airplane-style swirls off of the tail end. From standing behind the car and looking at the passenger's side of the rear window, the air rotates in a counter-clockwise half-circle on the glass, and it looks like it'll make a full swirl off of the car.
So, has anyone else observed this, or know if that's a detriment to drag?
Old 11-03-2009, 04:13 PM   #2 (permalink)
90 day: 51.82 mpg (US)
A pair of counter-rotating vortices are present at the rear of many vehicles. They were probably there before you added the vortex generators.
And yes, they're a "detriment to drag".
The way to avoid them is through shape optimization. Ideally you'd have a Kamm shape to your car (ie. extend & taper the greenhouse to the end of the vehicle) to get rid of them.
Old 11-03-2009, 04:46 PM   #3 (permalink)
Actually, they weren't there before I added the vortex generators. Before I added them, tufts were striaght along the sides and "bubbled" in the middle of the glass to the middle of the trunklid where the flow detached.
I'm wondering if I may have put the VG's too far forward.
Old 11-03-2009, 05:01 PM   #4 (permalink)
The VG's may have strengthened the vortices, but I'm betting they were more than likely there before.
Old 11-03-2009, 05:15 PM   #5 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
Did they help your mpg?
ollie
Old 11-03-2009, 05:22 PM   #6 (permalink)
Ollie: Not sure yet. I haven't had them on for long. I also got an alignment and new tie rod last week, so I won't be able to tell the difference in the MPG increase.
I also have a higher-flow muffler that I'll be installing this weekend.
Old 11-04-2009, 03:30 PM   #7 (permalink)
According to a French study (Peugeot/Citroen), the large counter-rotating vortices I'm getting are really reducing rear lift while also slightly reducing drag.
Their tests show that vortex generators are MUCH more effective at reducing lift than drag, and the large counter-rotating vortices I'm seeing on my rear window means that the VG's are doing their job quite well:
"It appears that the largest drag and lift reduction is clearly associated to a strong increase of the size of the recirculation bubble over the rear slant."
Here's the paper:
SpringerLink Home - Main
This is exactly what I want- Reducing lift, with drag reduction as an added bonus.
Old 04-09-2010, 01:40 PM   #8 (permalink)
Smurfback - '01 Chevrolet Blazer LS
mitsubishi's work backs up your account of increased down force on the the trunk. i'm dying to try this on my blazer which has no trunk to be forced down upon. where did you get your vortekz?
Old 04-09-2010, 01:49 PM   #9 (permalink)
Welcome to the site bgfshrcr. VGs have been covered many times over on this site. Time and time again they fail to produce any noticeable gain in mileage.
Old 04-09-2010, 02:49 PM   #10 (permalink)
I hear you Doax. Thanks for the welcome. Has anyone ever tried them on an SUV with no trunk or is there another possible such fix like a rear spoiler?
Tuft Testing - "Vortekz" vortex generators on 2003 Jetta Rear Window Deezler Aerodynamics 40 07-15-2017 01:56 AM
Belly pan or vortex generators? edbso Aerodynamics 125 02-22-2011 12:50 PM
Help choosing vortex generators Fit Aerodynamics 58 01-08-2011 04:08 AM
tuft testing, vortex generators, and God's own wind tunnel jim-frank Aerodynamics 10 06-27-2009 02:48 PM
vortex generators at rear bumper?? crexcrex Aerodynamics 14 08-22-2008 05:11 PM
