Old 02-06-2014, 02:28 PM   #1 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
syncro-mesh (how it works - youtube)
How a transmission works
- Tony
The Following User Says Thank You to arcosine For This Useful Post:
Joggernot (02-07-2014)
Old 02-06-2014, 03:14 PM   #2 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Maybe back in the 50s. Sliding gear transmissions have not been used since. In modern transmissions, the gears stay stationary and collars slide on the output shaft:
The Following 2 Users Say Thank You to mechman600 For This Useful Post:
Cobb (02-06-2014), Joggernot (02-07-2014)
Old 02-06-2014, 08:35 PM   #3 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
1936, I was looking for an example od a non-sycromesh transmission, like the reverse gear in your picture. Are then splines that the reverse gear slide on integral with the outout shaft?
- Tony
Old 02-06-2014, 08:39 PM   #4 (permalink)
So much for an intelligent conversation about the lubricant thats safe for yellow metals.
Old 02-06-2014, 08:42 PM   #5 (permalink)
That's a crash box (first post).
regards
Mech
Old 02-06-2014, 08:48 PM   #6 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
- Tony
Old 02-06-2014, 08:49 PM   #7 (permalink)
I prefer spinning hydraullic rams.
regards
Mech
Old 02-06-2014, 09:40 PM   #8 (permalink)
90 day: 38.47 mpg (US)
Meshing all gears all of the time seems inefficient. Perhaps they aren't loaded so the friction is greatly reduced?
These videos remind me of how a differential works.
Old 02-06-2014, 09:49 PM   #9 (permalink)
That's correct--there isn't a whole lot of friction because the gears are all spinning on roller bearings. Some power is lost just keeping everything moving, of course, but it's not as much as you might think from seeing that everything is always meshed.
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
Cobb (02-06-2014)
Old 02-06-2014, 10:43 PM   #10 (permalink)
Yeah, its easier to move spinning gears and to get them to mesh with others vs having them at a standing still. Thats assuming you are using gears in the first place.
