Old 10-07-2010, 10:31 AM   #1 (permalink)
Eco Amateur
AeroCav - '03 Chevrolet Cavalier
Air Dam Question
I've finally gathered up the components I want to use for an air dam. Now my problem is how to angle it
Which is more beneficial to a car?
1. |
1 | Verticle without lip.
or
2. / Diagonal
or
3. / Diganonal with lip.
_ /
From what I have read the only benefits of a lip would be when taking a turn at a higher rate of speed, but would it also help prevent excess air from going under the car by redirecting it along the lip line to the sides of the car?
AeroCav
Current Mods: Deleted mudflaps, Denso TT plugs, Synthetic blend motor oil
Future: Aero rim covers, air dam, grill block, full synthetic oil, synthetic transmission oil, reas wheel skirts, partial camback
Old 10-07-2010, 11:34 AM   #2 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
It's possible the lip would help, but it will never show up at the gas pump. If you like the look, and it doesn't make it dangerous for people walking by, I say go for it. If it would jump out and grab someone's ankle from time to time, DO NOT!
I would say go for diagonal, keep it at the front edge of the car as much as possible, and don't go further than the existing front end of the car if it looks like it will be a hazard to people walking by. No point in saving money on gas only to pay it out in medical bills.
Old 10-07-2010, 12:55 PM   #3 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
There are cases where a splitter helps over stock, but it's not necessarily needed. This is just a guess, but I'm wondering if a splitter would help if the dam is higher off the ground, because if it's lower, you won't really need it to keep excess air from getting under it.
In Reason we Trust
Old 10-07-2010, 01:08 PM   #4 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Slanting the air dam slightly forward has a similar effect as adding a splitter plate - keeping the air from flowing underneath the car anyway
On many production cars, the front spoiler has some sort of forward slanting lower lip.
Curving the air dam along the front of the car, or angling it slightly sideways from the center, will give the air a better place to go than underneath the car.
Old 10-07-2010, 01:12 PM   #5 (permalink)
I wonder why NASCAR would use a splitter when their air dam almost touches the ground... maybe it's just nit picking, but I bet it does something... like making the vertical air dam act more like a diagonal air dam.
Old 10-07-2010, 05:02 PM   #6 (permalink)
AeroModder's Avatar
Team Ford
In that case, it's for larger amounts of downforce. The splitter generates a high-pressure area just above it, and the air speeding below it drops in pressure. I was talking about using a splitter to reduce drag in my last post.
Here's more info on splitters: How Does a Splitter Work? - Page 1
In Reason we Trust
Old 10-07-2010, 05:13 PM   #7 (permalink)
AeroModder: Ah, downforce! I guess it makes sense when you think about it, like the high pressure area in front of a windshield, only to the max. I would assume that would mean the lower-drag option would be the diagonal air dam (better for our purposes).
Spydyr: Just as a side note, the general rule of thumb is that you don't make the air dam lower than the lowest part of the car you are shielding (lower at the wheels, higher toward the center).
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Lower Air Dam Zerohour Aerodynamics 2 07-28-2010 09:04 PM
Air dam and belly pan wildfire8 Aerodynamics 2 05-01-2010 12:04 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
