Originally Posted by Ardent
mpguino_1.86_tav.c loaded and appears to be working OK on the bench.
Good to hear!
Had one minor issue while entering initial parameters: Sometimes pressing one button would trigger the function of one of the other buttons, such as the right button would cause the value to increment instead of moving the cursor.
Interesting. Are you using the traditional button setup, or are you using analog buttons?
Could be my shady old hardware and/or user error though. ![Thumbs up](/forum/images/smilies/grinning-smiley-003.gif)
... No... I've seen that, too, every once in a while, but only when I used analog buttons. I figured that it would eventually be identified through testing. It could either be the analog button code, or it could be the choice selection code change that more easily enables support for more than 3 buttons at a time.
