Old 09-02-2009, 08:54 PM   #11 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
update... any info?
Pressure Gradient Force
The Positive Side of the Number Line
Old 09-03-2009, 07:12 AM   #12 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by RobertSmalls View Post
That would be a good first approximation if the pressure throughout the tire were uniform. However, it takes time for the pressure spike from the curb/pothole impact to reach the far side of the tire. Locally, the pressure could be quite high. Suppose I could tell you it's >200 psi for 0.05s. Is that enough to burst a tire or unseat the tire from the rim? Dunno, but as an engineer, I would recommend you close your eyes and ignore the pressure vs. time vs. position question, and pay attention only to the outcome. i.e. instead ask "To what cold PSI can I inflate a tire and still hit a pothole at 75mph without tire failure?"
That seems partially right - and partially wrong.
Pressure waves travel at the speed of sound - at standard conditions for air over 600 mph - at higher pressures the speed to be even higher. I don't think an object impacting a tire is going to go fast enough to generate more than a couple of 0.1's psi in the form of a wave.
Plus the biggest problem with tires impacting objects is the structural bending. You want enough inflation pressure to prevent the tire's sidewalls from bottoming out, which will cause a localized bending of the sidewall, thus breaking the cords. This is commonly called a "Rim Pinch" - the rounded curb scenario.
On the other extreme, if the object being impacted is pointed - like the edge of a pot hole might be, then the localized bending adds stress to the cords, particularly the inside ply cords. If the cords are already highly stressed due to high inflation pressures (the cords are pre-tensioned by the pressure), the cords could break. Needless to say, the more pointed the impacting object, the more likely the cords will break.
So you want enough pressure to resist bottoming out, but not so much to over-tension the ply cords.
And that, of course, doesn't take into account any other inflation pressure issues, such as fatigue and heat generation.
Old 09-03-2009, 01:15 PM   #13 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I'm writing some updates based on what I learned and will have them out soon, I hope!
Old 09-07-2009, 01:59 AM   #14 (permalink)
Old 09-09-2009, 07:18 PM   #15 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
Old 09-12-2009, 12:00 AM   #16 (permalink)
Ecomodder
Fr3AkAzOiD's Avatar
Cobalt XFE - '08 Chevrolet Cobalt XFE
Team Chevy
90 day: 41.1 mpg (US)
'05 Malibu V6 Tow Vehicle/Track Car - '05 Chevrolet Malibu LS V6
90 day: 23.12 mpg (US)
'08 XFE average for 2013 - '08 Chevrolet Cobalt XFE
Update?
Lifetime mpg
2012 mpg
Old 09-12-2009, 12:08 AM   #17 (permalink)
Maybe we know it all already.
Old 09-15-2009, 09:55 PM   #18 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
........."Crickets chirping".........
Old 09-17-2009, 10:36 AM   #19 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Yeah, I totally forgot about this thread... Looks like SVOBoy did too. Though I think he is too busy working on the CRX conversion.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 09-17-2009, 11:52 AM   #20 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Very likely, everything we want to ask Bridgestone is proprietary information.
