Old 07-28-2008, 09:02 AM   #1 (permalink)
Main Vehicle - '95 Geo Metro
90 day: 32.54 mpg (US)
The Tank - '01 Dodge Caravan SE
90 day: 15.69 mpg (US)
tank / current mileage problem
The MPGuino works great including calculating the tank and current mpg. It would save everything but for some reason now it doesn't save the tank or current mileage when I shut off power. Could my freeduino have a broken solder connection and if so which one controls the memory? The system menu doesn't adjust the cpu or the memory, it stays static at 450.0
Old 07-28-2008, 11:41 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I have the same issue...never saves the tank when I key off. Might be something I'm doing but I haven't had time to check it out, to be honest.
Old 07-28-2008, 07:46 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
The mpguino needs constant battery power for one (on with key off/key in run/key in start).
But I would start by reloading the latest version of the code if you have confirmed battery power.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
In a world where Jeeps get horrible gas mileage.... EcoJeeper Introductions 16 03-26-2009 12:09 PM
Perhaps honda specific: Will a code 41 (o2 sensor heater) tank my mileage? SVOboy Off-Topic Tech 13 08-04-2008 09:35 PM
Smaller Fuel Tank steensn EcoModding Central 5 07-11-2008 01:09 PM
