Old 05-14-2011, 07:29 PM   #11 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I have the opposite issue with my VW. I use key off to shut down the engine so far, and that also cuts the headlights while the key is off.
This is bad at 3am when I'm on my way to get my van for work...
Old 05-15-2011, 06:23 PM   #12 (permalink)
Easter McoModder
SwamiSalami's Avatar
'99 Subaru OLL 2.5L - '99 Subaru Outback Legacy Limited
90 day: 22.57 mpg (US)
Rabbit - '08 VW Rabbit S
90 day: 32.93 mpg (US)
This is probably the easiest mod for a beetle driver to make.
Old 05-18-2011, 04:34 PM   #13 (permalink)
I've Been AeroHauled
Anyone consider replacing the lights with LEDs?
Old 05-18-2011, 05:35 PM   #14 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by Arragonis View Post
I don't have DRLs on my (or Mrs A's TDIs) but we both run with headlights on (Xenons).
The result may be 1-2% MPG loss but to be honest a mistake on timing a light or timing a lane change or selecting when to shift up/down on a hill may make the same difference for or against FE on most journeys.
The positive result of lights on is that we have cut down the number of people pulling out without 'seeing' us by quite a bit. It is amazing how many do a double-take before deciding not to set off from a side road or change lanes.
So I'll stick with the lights.
I kind of like them too. Maybe soon there will be an LED option...
I'm not coasting, I'm shifting slowly.
Old 05-18-2011, 09:25 PM   #15 (permalink)
Easter McoModder
I've considered it for the time that I AM driving at night and thus, need the headlights. I don't know, though. I haven't priced any for my car, but I can't see this as being worthy of my time. Perhaps if I was driving my dream car or circumstances were somehow different.
Cheers
Old 05-19-2011, 12:49 PM   #16 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I think for DRL LEDs would be great. They are low power and produce a lot of glare. In daylight that is what gets attention.
As far as legality I doubt if there would be any repercussions from not running them. Some cars have them, others don't. Nothing to worry about. Cops have bigger things to worry about, like criminal activity.
Noah Webster, 1787
Old 05-19-2011, 03:51 PM   #17 (permalink)
Adela - '07 Chevrolet HHR 1LT
Team Chevy
90 day: 27.78 mpg (US)
Thats exactly the same way that I feel. And if some distracted driver pulling out of a driveway doesn't see my DRL-less car that undisputably has the right of way and T-bones it (or a similar collision situation), that would definitely cost me more in time and money and aggravation than a 0.5 MPG hit. (this nearly happened Sunday evening on the way to dinner, but when I had my lights on)
Old 05-19-2011, 04:00 PM   #18 (permalink)
Easter McoModder
evening is different than daytime.
Old 05-19-2011, 04:59 PM   #19 (permalink)
Corrado TDIsm - '90 VW Corrado TDI
90 day: 44.76 mpg (US)
I disabled the day time running lights on my mk4 2003 Jetta by bending one of the electrical pins over on the headlight switch. Some have removed the wiring from the plug side and others have covered the pin with electrical tape. I wanted it to look stealth and the elctrical tape didn't work for me.
It was very easy to do but I can't recall what pin number it was since I did this back in 2003.
Old 05-19-2011, 06:24 PM   #20 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
I don't have a VW w/ DRLs so I'm not sure about this. Isn't there a switch on the hand brake lever? Lift that to the first notch to test. If so I bet you could bend that open so it never makes contact.
daytime running lights, drl, new beetle drl, tdi drl
