Old 02-25-2009, 07:19 AM   #11 (permalink)
Taurus - '99 Ford Taurus SE
90 day: 17.89 mpg (US)
Windstar1 - '97 Ford Windstar Cargo
90 day: 16.99 mpg (US)
Vulcan - '97 Kawasaki Vulcan 750
90 day: 45.96 mpg (US)
Suzuki - '09 Suzuki SX4 Technology AWD
90 day: 24.62 mpg (US)
2003 Civic SI
Old 03-09-2009, 05:15 AM   #12 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I threw a teardrop into Flow Illustrator, going both forward and backward, with parameters Re=8000000 and dt=0.023.
ID:	2886Click image for larger version
Old 03-09-2009, 12:19 PM   #13 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 Honda City iDSI EXi
90 day: 47.47 mpg (US)
I think the ideal shape is neither the forward teardrop nor the reverse one. The objective here is to avoid a detached flow- the forward teardrop pushes a sizable wall of air, the reverse one allows turbulence to form at the end face, increasing drag.
The Ideal shape would be a combined teardrop with the front end formed by a reverse teardrop tail and the back end formed by a normal teardrop tail. The intermediate section can be tubular shape that then reaps benefit of a parting already taken place - something like the bullet trains of Shinkansen Japan or TGV France.
Old 03-09-2009, 01:02 PM   #14 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
I'm pretty sure, dispite intuition, that for a given vehicle length and height, the teardrop gives the best cd.
Old 03-09-2009, 01:10 PM   #15 (permalink)
Hi,
Here's the lowest Cd for a 4 wheeled vehicle:
The Schlor Pillbug (1937) has a Cd of 0.13. Food for thought!
Old 03-09-2009, 01:14 PM   #16 (permalink)
That's a sweet ride
Any of your aero folks want to punch that drag co-eff and a "standard" modern RR and weight into a hp calculator? I'd love to know how powerful of an electric motor that thing would require at 60mph.
Old 03-09-2009, 01:23 PM   #17 (permalink)
A teardrop is the optimal shape.... for a teardrop. In reality, a car has different constraints than a drop of water. And a flat nose is NOT the same as a rounded blunt nose, so please stop saying all these cars would be more aerodynamic in reverse.
Old 03-09-2009, 02:26 PM   #18 (permalink)
93 Metro Streamliner
AeroMetro - '93 Geo Metro
You can see that the pointy nose forward gives much better flow underneath the object, where it quickly attaches again. It will also have less pressure in front.
You can also see that having reduced slope behind is better for keeping the flow attached. Which leads to believe that the teardrop is NOT the ideal shape. Maybe something like this would be better:
ID:	2888   Click image for larger version
Old 03-09-2009, 02:44 PM   #19 (permalink)
Someone put that shape through flow illustrator, but use the same height and length as the teardrop.
Old 03-09-2009, 02:50 PM   #20 (permalink)
hypermiler01 post 18 -- You're in my camp!
Index of Phil Knox Aerodynamics Seminars & Mod-data lists TestDrive Aerodynamics 21 11-21-2022 09:57 AM
Aerodynamics Seminar #1 - by Phil Knox MetroMPG Aerodynamics 7 08-08-2012 06:00 PM
Hexagonal Dimples as a way to improve aerodynamics Palionu Aerodynamics 29 10-27-2009 12:39 AM
Aerodynamics Seminar # 5 - by Phil Knox MetroMPG Aerodynamics 4 01-29-2008 01:41 PM
Aerodynamics Seminar # 4 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:36 PM
