Old 12-11-2012, 04:14 AM   #1 (permalink)
Doesn't do, "normal"
Project UpCycle - '01 Honda Rebel Streamliner Build
Team Streamliner
Homers Hybrid - '08 Toyota Highlander Hybrid
moms car - '97 honda accord lx
90 day: 34.93 mpg (US)
Adventure - '98 Mazda Protege
90 day: 33.11 mpg (US)
The Silver Civic - '02 Honda Civic
90 day: 36.15 mpg (US)
6hp GM 24v DC electric motor $50 good deal?
Here is the ad
GE Motor Model 5BT1324B54 24 volt DC @ 6 HP from a forklift.
RPM @ 1150,
V 19.5, A 355,
ENCL OFC,
Serial # OH-9-1347-OH.
P/N 27900-00. AU1840.
He wants $50 for it, is it a good deal or should I pass on it, would it be enough for a 55mph ev?
Old 12-11-2012, 07:59 AM   #2 (permalink)
Do you know the diameter and/or the weight? It sounds like a good deal, but you'd have to inspect it to make sure the bearings are good and check the condition of the brushes.
Old 12-11-2012, 08:18 AM   #3 (permalink)
Team Streamliner
after two minutes on google I can't find the weight. judging from a picture of it though it looks to be around a foot across maybe?
Old 12-11-2012, 08:28 AM   #4 (permalink)
Depending on the vehicle you're thinking of putting it in, a couple inches can mean it fits or not. It also has a fairly large effect on torque output of the motor if you're going to be picky at all about that. Going from 10" to 12" gives you 20% more torque at the same RPM. Of course at the same voltage, you loose 20% of your peak RPM.
Old 12-11-2012, 08:34 AM   #5 (permalink)
Team Streamliner
In all honesty I want to build a side car and attach it to my motorcycle, converting it to EV and streamlining it, and if I end up getting a car to put it in, it is going to be a 40s/50s model car with plenty of engine compartment space.
I am not picky about torque, I drive a 233cc motorcycle every day. I might upgrade to a 500cc bike eventually, but it would have three wheels and a cabin
Old 12-11-2012, 08:47 AM   #6 (permalink)
That motor would be massive overkill for a motorcycle. If it really is around 12" in diameter its probably going to weigh well over 100 lbs.
Old 12-11-2012, 08:58 AM   #7 (permalink)
Team Streamliner
Right now I have a gas/ethanol powered motorcycle. I eventually want to build an electric car. My budget is small but I want this to be an evolution, one so I can learn, and two so I can take little bites out of the final cost.
Start with the bike, streamline it, add a side car, make it electric, streamline it again, find a donor car, move the electric parts to the car and streamline that [Unless it's a classic, then I might just do a riveted boat tail or something and keep it classy.]
By massive overkill are you meaning based purely on weight or power too?
Old 12-11-2012, 09:14 AM   #8 (permalink)
I'm saying if that is a 12" motor, it will move a pickup truck with ease. Its gonna be really hard to shoehorn that thing into a motorcycle frame, and its going to be massivly heavy. You might want it for a car project if that is something you're looking to do in the future. I wouldn't use it on a motorcycle though.
I just did some research on the motor's weight. Its not the same, but a Warp 11 motor weighs 225lbs. A Warp 13 weighs 367lbs. So, your 12" motor is gonna weigh in the high 200lbs range. That is not too far from the weight of a lightweight motorcycle itself!
Old 12-11-2012, 09:19 AM   #9 (permalink)
sr185 bullet - '81 Yamaha SR185 streamliner
Team Streamliner
90 day: 96.35 mpg (US)
Sunny Colarado - '06 Chevrolet Colarado WT
90 day: 24.18 mpg (US)
cbr250s - '12 Honda cbr250
90 day: 115.29 mpg (US)
sidecars tend to hurt fe quite a bit. you'd be better off doing a trike. this motor sounds like it'd be great for a streamlined trike. I looked around, because I know 12" is huge for a forklift. this looks like a pump motor, and is more likely in the 7" range. also, the tiles behind it are likely 12", and it doesn't look that big in comparison. I would buy it if it works at all. worst case scenario, you could resell it to someone looking to do a full conversion.
Old 12-11-2012, 02:20 PM   #10 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
The only reason not to buy it is that it doesn't look like it has an output shaft, so it's either a splined socket or a slotted drive plate that mates up to the pump on the forklift.
My 36v 2.5hp motor is around 35-40 pounds, 6.7" across and 9" long, at 36v it will make my motorcycle go 40mph and I figure at 48v it will make it go 55mph, 72v and I should be going around 65mph.
I road my motorcycle with 400 pounds of batteries on it and I would not want to have a 200 pound motor on a motorcycle.
