Old 04-05-2015, 02:09 PM   #11 (permalink)
wdb -- Get a little 50w panel set up and start monitoring it. You can gather info for up to a year before you need to do more; and the longer you wait, the cheaper and more efficient the available panels will be.
Old 04-05-2015, 08:59 PM   #12 (permalink)
Originally Posted by nimblemotors View Post
Do you really need a 4,500 lb car? If you haul around 6 people, then burning gasoline to do it is not a bad use of fossil fuel. If you drive solo, like 70% of all car use, then you would have a 'electron guzzler', or 'gross e-polluter' car.
Yeah, exactly my problem. But on the other end, the Roadster doesn't have enough room for me and my two dogs, the Leaf doesn't have enough range...
