Originally Posted by Occasionally6
Once set up I can't see how it can be inaccurate. It might be worth using a regulated voltage for the reference - as per the breakout box at the end of the article.
Apparently the reason it can be inaccurate (and probably is on at least some [most?] cars) is that it assumes a certain O2 sensor reading necessarily means the ECU is putting the engine into open-loop operation. As the article explains, however, the ECU is most likely considering other factors besides the O2 sensor output before it decides whether to enter (or leave) open-loop. That seems to me to make sense. Does anyone know differently?
It seems that the most accurate indication would be one (if there is one) given by the ECU itself. Otherwise, the open/closed loop state must be inferred somehow. Going to open-loop simply means that the ECU is relying on its own internal table of values instead of data from sensors -- does it tell us somehow that it is doing so, or does it just proceed to do so in secret, leaving us to infer the state of operations?
Today I inquired of the folks at UltraGauge how that instrument detects the open/closed loop state. The reply was:
"There is a parameter defined in the OBDII specification which conveys various bits of information, including loop status." This seems to verify that at least for the Mk-1 Ford Focus (which I inquired about) that the ECU does give a definite indication of the open/closed state. However, the answer seems to indicate that this information must parsed out from a particular
"parameter" stream that includes some other data.
I think therein lies the clue for how to determine the open/closed state by some independent means.
That said, for me the best solution would be if UltraGauge would devise an update that would make the 8-instruments page configuration modify the vertical column separator line to indicate the state (dashed line or solid). Even on the 4- and 6-instrument page configurations, though, the indicator is small and hard to decipher when on the road.
I think an accurate indicator of this is vital to hypermiling. I will continue to investigate how to make an accurate, independent indicator when time allows, if an update to the UltraGauge isn't forthcoming.
