08-24-2008, 06:17 PM
#31 (permalink)
Deadly Efficient
Rain on my parade, will ya, Randy?
I figured the (lack of) efficiency of the vortex tube might be what makes it undesirable.
Schlepping ice before every trip just doesn't appeal to me.
I like the fan-cooled seat cushion idea, too. Waiting for Daox's review.
I also like Trik's idea of the electrically-driven Goldwing compressor. Just haven't had time to research it yet. I suppose I could put up with recharging a battery every night.
-Terry
08-24-2008, 09:43 PM
#32 (permalink)
Mr. Blue Tape
An ice filled cooler with a small electric fan to blow air over it will do a lot too -- add in some calcium chloride to the ice and now it will act as a desiccant and PULL water out of the air (and solve some of the high humidity issues).
But I still like the absorption cooler only because it speaks to the MacGuyver in me.
My 5 pillars of fuel efficiency:- driving style
- aerodynamics
- tires
- weight reduction
- engine maintenance
08-27-2008, 06:44 PM
#33 (permalink)
Okay, let me drop a different idea. What if you had a vehicle powered by propane (or LNG for that matter) instead of gas? Tap off the bottom of the propane tank and run the liquid fuel through the AC evaporator set prior to sending it to the engine. When you are not using the AC, use exhaust gas to warm up the evap. In fact, you could use the exhaust gas to preheat the propane to the optimal combustion temp as necessary.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
08-27-2008, 09:06 PM
#34 (permalink)
EM Noob
The coolest cooler takes advantage of God's brain
The most efficient cooler is the one God built into all of us, evaporation from the lungs, sinuses and skin interfacing to the bloodstream, and what feels best beside. So think in terms of moving the air a little bit (so some kind of fan for one end and maybe the seat cushion gadget for the other) and drying the air in the car when it goes above a certain percent relative humidity. Some kind of chemical humectant that can be re-dried out at home in the microwave would be lots more efficient that current compressor coolers. No moving parts is good. Not sure about cost.
You'd want to keep the air recirculating to keep out the outside humidity. So the air temp might not be 70, but a dry, moving 90 degree airstream will feel cooler to you than a still, clammy 75, you crazy mammal you.
Oh, and tint your windows with heat-reflective film. And paint the car white if it isn't.
I once drove across West Texas in July with no A/C. The key was block out the window to keep the sun directly off ya, and keep the air moving. 110 degrees and it wasn't all that uncomfortable.
HaPPI
08-27-2008, 10:04 PM
#35 (permalink)
Deadly Efficient
Yup, tinting the windows is definitely on the to-do list.
Doax's cushions might be the simplest solution yet. Or at least the start of an efficient system.
-Terry
08-27-2008, 11:44 PM
#36 (permalink)
testing the waters
Get it done
Yall guys are making this too complicated, lets actually get it done instead of adding tripple turbos, and solar shenanigans
Plan A) Basic, redneck approach
1) Get a 12v oscillating fan from walmart that plugs into the cig adapter.
2) Coil Copper tubing behind it
3) Use an aquarium pump to circulate ice water through the coils
4) Draw the ice water from a super insulated ice box (like the orange gatoraide coolers)
5) Make sure there is an emergency 6 pack in the ice box at all times
Plan B) Nicer approach
1) Use the car's existing blower motor to drive the cool air, and use existing ac controls
2) Stick a copper coil in the duct work, or in the blower motor assembly
3) Circulate the water from the icebox from the trunk, rout it down below the vehicle near like a fuel line, and install a heat exchanger (small heater core) inline to keep the ice water (or whatever fluid) cooler, longer.
You could even put the heat exchanger up near the grill or in a fender well, anywhere it will get cool air.
You shouldn't need to add ice but every few days
08-28-2008, 12:50 AM
#37 (permalink)
EM Noob
One more thought about a fan
I'm a fan of fans, TC. I just had a great idea for where it would cool you off best - mounted on your headrest, on the side or top, pointed at the back of your head. A little muffin fan extracted from dead electronics such as a PC power supply is 1) free, 2) 12VDC, 3) draws maybe .3A and could even be run from a 4.5 watt solar cell (WalMart auto dept, around $40, as I recall) on the back window ledge.
With it so close to your ears though, you'd have to pick a quiet one with a slow rpm to not drive you deef. Or if the headrest has an arch to it and a gap between it and the seat like some cars do, put it behind the headrest at the bottom so that the air goes between em.
HaPPI
08-28-2008, 07:24 AM
#38 (permalink)
forgottenmindset,
I can assure you that it will be more often than just "every few days." I know a little about the gatoraid coolers... Back in my high school days, I played football. Just before school started, we had summer "two-a-day" practices. First practice was ~8:30am, second around 3:30pm. The junior varsity guys had to make the ice water and they were, um, encouraged to get to the ice machine early before the afternoon practice. Why? The ice from the morning practice would be practically gone by the 3:30 practice, even when stored in the shade. (And the last group to make up their jug didn't get much ice.) Sure, we are talking about Louisiana heat. But you're looking at storing your ice inside a vehicle, where the temps can go over 130F pretty quickly.
08-28-2008, 11:01 AM
#39 (permalink)
testing the waters
Hmm, ok so just add ice everyday
But with the window tint and the cooler in the trunk, I think it would stay pretty cool in the cabin already
What about this, seal the circulating system water (just like the r134 gas is sealed), and keep dry ice in the cooler which has no direct contact with the copper lines, I dunno just thinking out loud here
Also a mabey better idea is to have a really high pressure water pump shoot mist through you blower motor, it wont be enough to make you wet, but it will cool in blowers intake air down tremendously
That's what they do at disney world, they shoot atomized water at fans way high up to shoot cool mystified air at the guests waiting in line. Works amazing.
08-28-2008, 11:54 AM
#40 (permalink)
Deadly Efficient
No
No
No
and
NO.
I'm not putting a swamp cooler in my car. It's already too humid in there.
And I am NOT schlepping ice before every trip. See requirement #2 in the OP.
-Terry
