Old 01-16-2012, 07:09 PM   #1 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
forced air intake by fog light holes?
i want to test on my 2005 toyota echo a forced air intake using Flexible Aluminum Ducting to take air in the front of my car by the fog light holes that act like a funnel. but before the test i want to know if it is likely to helps the MPGs or it will do nothing?
Old 01-16-2012, 07:31 PM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
If, by chance you can get an increase in pressure, then forcing more air in to the engine will have the affect of increasing the amount of gasoline that is needed as well, otherwise the throttle plate will have to close further, creating turbulence inside of the intake making the engine work harder.
It all depends on what your goal is and if the fraction of a psi of pressure you could get, less then 1/10th of a PSI, is worth the extra ducting that you would have to install
Old 01-16-2012, 07:38 PM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
here is a setup i made several yrs ago (pre-ecomodder) never tested it.
factory intake left in place:
front of car:
removed this:
leaving a hole in the bottom of the air box
installed this:
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
HyperMileQC (01-17-2012)
Old 01-17-2012, 08:54 AM   #4 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
This is really good informations, thank you so much!
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
Old 01-17-2012, 09:01 PM   #5 (permalink)
40-60-40 MPH P&G
Talking
front of car:
removed this:
installed this:
do you have problems with road dust or snow (if you ever driven in it )
and y know its not tested but do you think in was good or bad for the MPGs
Old 01-17-2012, 09:31 PM   #6 (permalink)
mcrews's Avatar
No snow.....no problem!!!!!
I'm a mpg nut.
I'm all about getting good mpg on the road. cant do much about city driving.
my gut feeling is that it helps.
Remember I have all the stock stuff in place.
I did but a small hole in the bottom of the elbow so IF any water got in there in just drains out.
rember the hole in the bottom of the airbox is in front of the air filter.
Can't say it gets more or less dirty, I have (all my life) cleaned out my air filter when ever I clean the engine compartment. which is about once a month.
I went thru a sand storm in southern az in august.....man does the sand build up in the air box!
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-17-2012, 11:10 PM   #7 (permalink)
just wanteds to quote the pics again. ahhhh
front of car:
removed this:
installed this:
Old 01-17-2012, 11:13 PM   #8 (permalink)
mcrews's Avatar
frank lee,
are you making fun of me???????
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-17-2012, 11:16 PM   #9 (permalink)
Not at all!!!
I simply love it when people repeatedly quote pics such that I can go in the kitchen, prepare a sandwich, and come back to the computer and the page hasn't even loaded yet. People, if it isn't vital to your reply, can you omit quoting pics? Thank you velly much.
Old 01-17-2012, 11:21 PM   #10 (permalink)
mcrews's Avatar
oh gotcha.......
(if you would feed the squirrel more that 1 nut a day, he might have the energy to keep the wheel going........
i'm just sayin!!!)
ECO MODS PERFORMED:
First: ScangaugeII
