Tips: corridor effect question
I tried going 55 on the Mass Pike a few weeks ago. I loved it. It was relaxing and I'm hearing it will increase mileage. But there was no ability to experience the "corridor effect" because people were passing me as though I was crawling. There was no one else going 55. Thoughts anyone?
to joycebgood:
Like so many addictions/habits they die hard. "Everyone" has become a fast driver. They all have to get somewhere to do nothing, or drink some beer. It has been a craziness for too many years. I dont think that high gas prices will turn them around. FYI the latest thing that I have noticed is that the hybrids (drivers) are speeding/driving like crazy. I guess that they think if they get good mileage they can speed. |
First of all, welcome to ecomodder!
It's hard to say whether the slow down or the corridor effect will improve mileage the most, but if you have a 96+ car I would say to get a scangauge and see for yourself! :) |
Slowing down will more than make up for the corridor effect. Even though they are blowing by you you still would get a little help especialy if it's a stream of traffic.
Now is it true that you can benefit from someone drafting you? Or in our cases tailgating you .. LOL
I'd recommend the 4 second rule as taught in driver's ed. Even as ecomodders, safety should come before economy. |
Theoretically, two blunt objects sitting tandem in a flow will each see a decrease in drag. The rear object will see a much larger decrease, but the one in front will also see an improvement. It is most likely too negligable to see in real life (nor is it advisable).
Speaking from intuition, I doubt the corridor effect has any major effect on vehicle drag. I could only imagine it being useful in tunnels or maybe alongside massive soundwalls. Drafting on the other hand, while dangerous, is proven. - LostCause |
To rule out the noise of the draft effect, during calm winds, the boost isn't as dramatic. In the 'Teg, the x-wind scenario generally boosts FE by roughly 7 MPG, where the "passing draft" gains closer to 3-5. This is generally all of 10-seconds, so you'd have to hang in the "unsafe zone" to take full advantage. On a 3+ lane highway, I often LOD up hills similar to semi trucks. Many build-up momentum to pass in the center or right-center lane and offer up some "help" to climb the hill. I won't make it a habit to maintain side-draft exclusively in the exact same spot. We're each using LOD differently and often lose pace. This doesn't upset the truck driver like full draft does. For smaller vehicles in a tight corridor formation, this would have to be studied further for solid data. RH77 |
