Old 04-23-2019, 01:05 AM   #1 (permalink)
Spanish whip - '12 Seat Ibiza ST E-Ecomotive 1.2 TDI
90 day: 53.84 mpg (US)
Tire choice, 145/80R14 or 175/65R15
I need to buy new tires soon and IÂ’m wondering which is the right choice.
My original size is 185/60R15.
IÂ’m thinking of these sizes to replace them:
175/65R15
145/80R14
The 175/65R15 are available as fuel efficiency class A tires (Continental ecocontact 6). They are 1% larger than original.
The 145/80R14 are original Lupo 3L tires which have a C fuel efficiency rating (Bridgestone Ecopia B381). They are 2.5% smaller than original.
Old 04-23-2019, 08:12 AM   #2 (permalink)
Go with the 15 inch wheels.
14 is becoming a dead size to some tire manufacturers.
There is a big difference between a fuel economy A and fuel economy C. I put a pair of fuel economy C tires on my nissan leaf it really killed the range. I would have really been in trouble if I had replaced all 4.
And you don't want to go smaller on the diameter.
Old 04-23-2019, 08:43 AM   #3 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
A narrower tire will have less angular momentum and will decrease energy lost in stop and go traffic. It will also improve aerodynamics. However, an 80 aspect ratio is really tall, and suspension will be better tuned for the 175 width. The tread compound will probably hurt more than the rest helps. I doubt rolling resistance will be lower. I'd also vote for the 175's.
Old 04-23-2019, 11:30 AM   #4 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
I would just throw on 165/65r14 RE92s in that application but I bet they don’t have them over there
Old 04-23-2019, 12:57 PM   #5 (permalink)
Little Blue Fuel Sipper - '16 Nissan Versa SV Sedan
90 day: 45.75 mpg (US)
The 175/65-15 is going to give you taller gearing than the 145/80-14. I went with tires that gave taller gearing on an '88 Ford Escort I used to drive and saw an increase in fuel mileage, but the tires I was using were 6.5% larger. Here's another vote for 175/65-14.
Old 04-23-2019, 06:53 PM   #6 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
I also vote for the 175s, diameter usually helps mileage, and the better compound will help by itself... I went 5.3% taller on my Saturn and gained mileage even though I also went wider
My current Ecotec project...
My last Ecotec project...
Old 04-23-2019, 09:43 PM   #7 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
The 175s have a much better rolling resistance rating. You'd have to pump up the 145 width tires to some pretty hefty PSI to match the 175s.
In most cases,
LRR > width
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 04-28-2019, 11:06 AM   #8 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
175/65R15
145/80R14
The difference if FE isn't going to pay for a new set of wheels, or eat it all up, so no benefit ...
Far more expensive tyres might not recoup their investment in reduced fuel (depends on fuel price and FE of course).
The 175s are generally a bit cheaper (at least in Belgium) than the 185s.
But difference is minimal.
You can get the Nokian eLine2 in 185/60 ... AA rated and not excessively expensive
The 145/80s are C rated rather than A, and choice is very limited ...
14" is still doing fairly OK in Europe
Smaller diameter rims are generally lighter
Metal is lighter than rubber, so diameter increases are best done using rubber rather than metal ...
Old 04-28-2019, 12:45 PM   #9 (permalink)
I saw a post on the nissan leaf forum where a guy got some ultra light weight racing wheels for his leaf.
New they were over $600 each, he got them second hand for cheap. These wheels where half the weight or about 10 pounds lighter than the stock wheels.
Only increased range by 2%.
You get more range than that just by going with a good LRR tire.
Old 04-29-2019, 12:50 PM   #10 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Has anything beat the 165/65/14 re92?
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
