Old 10-07-2014, 06:03 PM   #1 (permalink)
Tire "eyebrows"
I've noticed car manufacturers are now putting little flaps in the underbody, projecting down, just in front of the tires. What is that about? Is it an efficiency measure?
Seems to me they would work better if larger and lower, and angled so the air exits outside rather than under the car. It would be pretty simple to screw larger flaps right to the original ones. The chloroplast would be "sacrificial" so you could put it quite a bit lower toward the ground, and not worry if it hit something.
Old 10-07-2014, 06:07 PM   #2 (permalink)
Woops, never mind, I just saw that other thread about "spats". Didn't know the name of the things...
Old 10-07-2014, 06:12 PM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Thank you for using the power!!!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Xist (10-08-2014)
Old 10-08-2014, 12:51 AM   #4 (permalink)
We've all been there.
Take a look at Basjoos' Aerocivic. You'll see the OEM spats were watered down in commitee. He uses inner and outer walls between the front and back tires to channel and block the air. Plus pronounced spats fore and aft. It seems to work.
