Old 04-28-2008, 09:49 PM   #1 (permalink)
I REFUSE!
thebrad's Avatar
VTEC Express - '96 Honda Civic CX
90 day: 57.72 mpg (US)
Send a message via AIM to thebrad
Tire over inflation problem
I've been running 60psi for the past few weeks and noticed this tonight:
So deflate or see how long I can go without issue?
Old 04-28-2008, 10:02 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
What is it? I can't really tell, does the tire dip in?
Old 04-28-2008, 10:14 PM   #3 (permalink)
pontiac trans am - '00 pontiac firebird trans am
jeep 1 - '02 jeep wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 jeep wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Toyota Corolla lx
if the tire is just dipping in (like a valley) then it is nothing to worry about, that is where the material inside the tire overlaps and so it restricts the outward expansion of the sidewall. if that is a bulge that we are seeing than the plies in the sidewall might be seperating or have an internal leak at which point you would need the tires to be replaced
Old 04-28-2008, 10:18 PM   #4 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I had two tires split at the valve stem. One actually started to leak so badly that I had to change the tire.
My max PSI is rated at 44PSI on the sidewall, and I was running 55 PSI, but on the day of the tire failure, I filled them to around 55 or so ........... and found out later how inaccurate that tire guages can be. I was actually at around 65- 70 + PSI.
( So it's a good idea to check the pressure with more than one guage. )
In my particular case, both tires failed at the valve stem. In your case, it appears to be the tire itself. I would deflate to normal levels and have a tire shop check the tire.
Better to do that then to put you life, as well as others in danger for a few pennies worth of gas.
I have seen similar marks on tires before that were at normal PSI levels. It may be common actually , and something that you only notice in certain lighting conditions.
I actually had this sort of mark on the tires that I used before my current set.
It always bothered me.
I would get a second opinion from an expert.
Stay safe !
Old 04-28-2008, 10:20 PM   #5 (permalink)
Cd
Ultimate Fail
Cd's Avatar
60 PSI ? What is the max. sidewall rating ?
Old 04-28-2008, 10:57 PM   #6 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
All of my Sumitomo tires have had that bump on their sides from day one, just an artifact of the manufacturing process. I've been running 60 psi in them since I got them last June with no problems.
aerocivic.com
Old 04-29-2008, 12:53 AM   #7 (permalink)
I REFUSE!
thebrad's Avatar
Sidewall max temperature is 51 psi.
The two pressure gauges I have read the same amount, albeit they are both rather shoddy.
Sorry I couldn't manage to get a better picture of it, but yes it's just a little dip in the sidewall that runs the height of the tire.
Old 04-29-2008, 04:29 AM   #8 (permalink)
nothing to worry about then, i've seen thousands of tires do that (used to work in a tire shop), its all in how its made and not a defect.
Old 04-29-2008, 05:30 AM   #9 (permalink)
Blue - '77 Chevy P/U
a good gauge is a must ,,, i like to look at cold and warm/hot readings on my truck
Old 04-29-2008, 09:58 AM   #10 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by .Cd View Post
I had two tires split at the valve stem. ...
I'd like to correct the terminology a bit: I wouldn't say that was a tire failure at all. The valve stem and tires themselves are physically separate items. Sounds like a valve stem failure, not a tire failure.
My Accord also had a set of tires with the "dip" in all four sidewalls. I don't think the Goodyears on the Flea have them though.
Tubless tire repair kit information Silveredwings Off-Topic Tech 21 08-30-2017 12:28 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
Alternator problem!!! HELP!!!! bennelson Off-Topic Tech 10 03-26-2008 10:43 AM
Article: Green push hits tire makers MetroMPG General Efficiency Discussion 0 12-16-2007 07:14 PM
