Old 03-12-2010, 02:41 PM   #1 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
Smile Tire Purchase
Tire Purchase Decision ???
I am in need of tires for my 04 Prius. Prius chat forum is full of posts about LLR and OEM. One thing is for sure price vary from low $60 uninstalled per tire to the high side of $110 . Understand all new tires will require breakin time. Also if you have a brand you like on this vechicle type and had good results please post appropiately
04 Prius
Michelin Destiny tire size 185/65 TR 15 (current tire)
$620 (4tires)replace price of above tire at Discount Tire (not locally stocked)3/4 day turn time
$500 (4tires)cooper tire 80000 mile
The mount/balance costs $19-20 per wheel
thanks to all
TexasCotton
Old 03-14-2010, 12:31 AM   #2 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
texas look at the ecopia bridgestone/firestone it was #2 in the low rolling resistance tire comparison on tirerack.com . they scored high on wet traction tests also and are priced right as well.i think they used prius in the test,,worth a look.
The Following User Says Thank You to moonmonkey For This Useful Post:
TexasCotton (03-15-2010)
Old 03-14-2010, 12:52 AM   #3 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
I would get one with good handling and braking. You never know when you need to drive 95.
The Following User Says Thank You to MadisonMPG For This Useful Post:
Old 03-15-2010, 10:52 PM   #4 (permalink)
Hey ur profile shows madison. How far/what direction est roughly is that from Wetumpka aka N Montgom.
The current michlen destiny have nice handling for high mileage wear tire.
Old 03-16-2010, 10:26 AM   #5 (permalink)
About 3 hours, Madison is like the very top of AL.
Old 03-16-2010, 12:54 PM   #6 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Here's the TireRack test mentioned earlier:
When Round and Black Becomes Lean and Green
The Following User Says Thank You to PaleMelanesian For This Useful Post:
moonmonkey (03-16-2010)
Old 03-19-2010, 02:34 AM   #7 (permalink)
The light weight wheel can give benefits in roadholding and handling because of the reduced unsprung mass of the wheel assembly.This means the wheel needs less energy to move in response to bumps, so improving the ride and keeping the tyre in contact with the road surface for a greater time. However this benefit can be lost if the wheel is bigger than the standard, or the suspension is stiffened from standard.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
"Inflation pressure does not affect grip": Autospeed article. orange4boy EcoModding Central 158 05-06-2010 03:29 PM
Measure tire rolling resistance with a bounce test Ernie Rogers EcoModding Central 8 01-08-2010 07:36 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
