Old 07-16-2011, 04:19 AM   #11 (permalink)
Knight - '07 Chevy Cobalt LS
Chevyteg - '95 Acura Integra LS
alright, looks like I'll definitely be getting these tires then.
Old 07-19-2011, 05:40 PM   #12 (permalink)
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Nissan Frontier XE
90 day: 27.87 mpg (US)
Originally Posted by camopaint0707 View Post
really? a taller tire is better?
It depends on your driving, your gearing, and how much power your engine has. If your drive the freeway at 75 BUT your rpm's are low at that speed and you have very little power to spare left (is the car still responsive in top gear at your highest speed), then bigger tires will increase your top gear to be taller than ideal and you may need to downshift out of your top gear more often. Manny newer cars have very tall overdrive gears that don't run the rpm's up until you exceed 80 mph. If that is the case, your gearing is ideal and you probably don't want to mess with it.
If, however, your RPM's run high at your top cursing speed and your car feels peppy and responsive to throttle as a result, you should benefit from larger diameter tires. The added weight and height will be outweighed by the RMP reduction. If you have a transmission with 5 speeds or more, the taller gearing will be an even greater benefit.
Most of time time for most cars, bigger is better.
Old 07-19-2011, 06:07 PM   #13 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
and the b381 are the best llr tires out there?
Sorry to say that I don't think there are any up-to-date data available online. Anyone know of data out there that is current?
Old 07-19-2011, 07:56 PM   #14 (permalink)
Well I used the review of those tires from this site. Whoever wrote it said the B381's are the best LLR tires period.
