Old 07-24-2008, 07:55 PM   #11 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Originally Posted by ATaylorRacing View Post
Those Weld wheels are great for the track but WAY to fragile for street use. I had some Kosei Racing rims that were street legal but all four had up to a tenth of an inch wobble after 2 years of babied street driving and lots of drag racing...never curbed. I say go to Diamond Racing Wheels then click on their ministock button. They have steel wheels that should be tough enough...various 13s & 15s and bolt patterns. Their 13x5.5 with 1 to 3 in of back space is only 10.5 lbs and cost is $75.50.
I apologize for threadjacking, but at least in my case, that's not an option. 14"s are the lower limit for modern small Toyotas (the Echo, xA, xZ, Prius, Yaris), so at that point, good lightweight alloys are a better choice.
I wish I could use 10# 13" steelies. That would be really sweet, actually.
Old 07-25-2008, 02:44 PM   #12 (permalink)
Larger diameters (to raise gearing), light weight, high pressures and slicks are all good to some unknown extent.
Other than that, I can't find a clear pattern as to what gives significantly better mileage.
civic, honda, size, tire
Tubless tire repair kit information Silveredwings Off-Topic Tech 21 08-30-2017 12:28 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
New tires, advise? Chris D. EcoModding Central 35 06-09-2008 09:53 AM
Article: Green push hits tire makers MetroMPG General Efficiency Discussion 0 12-16-2007 07:14 PM
