Old 08-16-2014, 03:20 PM   #11 (permalink)
Camry - '99 Toyota Camry
90 day: 39.84 mpg (US)
Yeah and I really like the tread pattern
99 Camry
Old 08-18-2014, 07:28 AM   #12 (permalink)
58psi, is that just a little over the max pressure? Dangerous?
Old 08-18-2014, 08:34 AM   #13 (permalink)
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Higher or lower UTQG does not necessarily correlate into rolling resistance, especially across different brands. I have seen it work both ways on different occasions. Way too many variables between tread patterns, tread compounds, psi ranges, actual diameters, etcetera to directly correlate.
Also to clarify the three UTQG ratings are for treadwear, traction, and temperature. The speed rating is part of the service description, which consists of a load index and a speed rating.
For example, compare the following:
Michelin LTX M/S2
Serv. Desc: 114T
UTQG: 720 A A
Dick Cepek Trail Country
Serv. Desc: 116T
UTQG: 500 A B
Yes, a bit of an extreme example, but it should be clear from looking at the tread patterns which tire has lower RR, and note that the UTQG doesn’t correlate.
The Following User Says Thank You to aardvarcus For This Useful Post:
sully06 (08-18-2014)
Old 08-18-2014, 09:40 AM   #14 (permalink)
Well the max is 51 I usually keep them at 55 but put a few psi more for the trip. I had 55 in the Goodyears which had a max of 44 for over a year. I knew the risks of having a blowout were higher but was ok with that.
99 Camry
