Old 11-21-2011, 09:13 AM   #141 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by bandit86 View Post
If A tire does not like to flex much would that not mean it should have lower rolling resistance? ..........
Sorry, but no. The fact that it doesn't like to flex - and the load on the tire is going to force it to flex - means that there will be more internal heat generated - and that's RR.
.....What about siping, does that make a difference?
The difference is small enough to ignore.
Old 05-01-2014, 06:16 PM   #142 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
Originally Posted by blackjackel View Post
$075 0.00864 Michelin Steel Belted Radial P205/75/R15
It appears that Michelin discontinued these or at least I haven't found them on Tirerack.com. Are there any brand new LRR tires of this size? I'm looking for some LRRs for the Chevy I have and it has this size of tire on it, The reason why I'm hoping for this size is so the odometer remains accurate.
Old 05-01-2014, 07:43 PM   #143 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
I think they might be sold only through certain places like sams club or costco
The Following User Says Thank You to 2000mc For This Useful Post:
101Volts (05-03-2014)
Old 01-12-2016, 04:04 AM   #144 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Can anybody fill me in on 13" tires? Civic CX wheels!
I appreciate any help.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 01-25-2016, 11:39 PM   #145 (permalink)
Taller and wider tires may have lower rolling resistance (according to that research). However it gets a little more complicated when you add other factors, such as the car gearing. If your car is geared fairly low, you might want to favor taller tires over wider tires, just to get the rpms down. In that case "tall and skinny" might be better. However if your gearing is fairly high, or where you like it, then you might want to go the other way because extra width with constant height does not change the gearing.
I went taller on my old '97 VW Passat TDI (the gearing was too low for my taste). The next change I went taller yet again. This time I ran into handling problems - it didn't feel as settled - and hitting a pothole (on gravel roads) with the wheel turned resulted in snagging the wheel well a couple of times. Fortunately it was a matter of getting a plyers and straightening the metal out again; not visible from the topside. I suppose if you had a nice car this might get distressing, heh, but my car had a lot of miles and it didn't bother me.
I believe both steps going taller added significant mpg even after correcting for the larger tire diameter (that is, lower reported odometer readings). Certainly the first step did.
I probably won't go with taller tires on my current Passat as it is geared nice and high.
Video: Can Skinnier Tires Increase Fuel Economy? Peakster EcoModding Central 67 06-06-2019 12:27 AM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 46 06-05-2015 04:24 PM
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
Looking for a fuel efficient solution. I've got a few ideas. CuriousOne EcoModding Central 41 03-28-2009 02:46 PM
FS: Set of (5) VX Rims with LRR Tires XFi For Sale 2 02-16-2008 02:49 PM
