Old 09-12-2013, 02:28 AM   #1 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Tried a little EOC today
And it was not so good. The Beetle TDI is a bit heavy for that. I can Armstrong the steering OK, but only get 3 brake applications before the brakes get really ineffective in an emergency.
There was too much slower traffic ahead for me to keep off the brakes.
I was descending down the west side of Mt. Rainier, dropping from 5000' to 2000' at Longmire. Lots of good energy to be had, but also a ton of switchbacks and slower speeds.
Before I tried it, I had the windows down and sunroof open to maximize drag. I daydreamed about a large speedbrake I could deploy out the sunroof when needed
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 09-12-2013, 07:21 AM   #2 (permalink)
Mirage 5MT driver
honda - '99 Honda Civic EX
90 day: 38.09 mpg (US)
Mirage - '14 Mitsubishi Mirage ES
90 day: 45.5 mpg (US)
I've read about a few EV guys using Vacuum pumps from turbo volvo's, I might be investing in one of these for my EOC although my civic doesn't take much effort without the vacuum booster its difficult for me to efficiently restart my civic (automatic) before the stop sign and adjust to vacuum boosted brakes after using no booster for the 3 mile 9 1/2% grade.
1999 Civic EX coupe Autotragic -MPG project best mpg 54.2 w/masking tape mods otherwise stock. -SOLD
2014 Mitsubishi Mirage ES 5MT. 15k miles 44.2 mpg avg overall in my mountain, northern PA
2010 Cobalt sedan XFE -project uber/mpg taxi.
The Following User Says Thank You to alex16 For This Useful Post:
skyking (09-12-2013)
Old 09-12-2013, 09:26 AM   #3 (permalink)
If you're going down a mountain just use DFCO...
Old 09-12-2013, 10:45 AM   #4 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I miss EOC. I'll be back soon.
Transmission type Efficiency
Old 09-12-2013, 12:17 PM   #5 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Here's the electric pump I'm using. 20" hg instant
http://www.summitracing.com/parts/ssb-28146
Pressure Gradient Force
The Positive Side of the Number Line
Old 09-12-2013, 03:27 PM   #6 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Ya, I've tried it with my Jetta TDI as well, and what worried me the most is difference in steering effort between engine off and engine running... bump-starting in a curve would cause me to nearly swerve out of my lane due to the difference in effort. A nice long straight = no problem... curvy = Yikes!
The Following User Says Thank You to NachtRitter For This Useful Post:
Old 09-12-2013, 10:03 PM   #7 (permalink)
skyking's Avatar
Major update!
I looked it over on the way up the hill today, and made a plan. I tested the braking and it was 6 even applications before the brakes went 'stony'.
I made a braking budget of 4. after 4, look for a good place to start it. That way I was not starting in a corner, NachtRitter
I did use DFCO for part of the trip down. I would start when the braking required it, and use some engine drag on the steeper section.
This amounted to 0.7 miles on an 11.7 mile EOC
Then a short 1 mile engine run on a smallish bump, followed by a 4.2 mile EOC run with two brake applications.
Then another 1.5 mile run.
and a 0.7 mile run.
This was on my 60 mile return trip from the mountain. I figure I coasted 17.4 miles on the way home today.
2003 TDI Beetle
2002 TDI Beetle
The Following 2 Users Say Thank You to skyking For This Useful Post:
101Volts (09-14-2013), snakester (05-04-2014)
Old 09-13-2013, 01:10 AM   #8 (permalink)
NightKnight
Diesel
Wow! That is a pretty nice coast!!
skyking (09-13-2013)
Old 09-13-2013, 01:29 AM   #9 (permalink)
skyking's Avatar
Yes it was! I had a ball doing it. I had some traffic on the 4.2 run that kept me guessing as far as strategy. Sometimes they were half a mile ahead, other times I was braking right up on them. Nobody was behind me. It was a real gas, using no diesel.
2003 TDI Beetle
2002 TDI Beetle
The Following User Says Thank You to skyking For This Useful Post:
Old 09-13-2013, 09:25 PM   #10 (permalink)
skyking's Avatar
I had nobody behind me today, so I rolled right out the gate and kept going. It was 16.3 miles with 0.8 engine on. This EOC is fun stuff.
2003 TDI Beetle
2002 TDI Beetle
