Old 09-03-2010, 08:30 PM   #1 (permalink)
VTEC-E for city running? is it worth it?
Hi all,
I do lot of city running ,and I was thinking of buying a VTEC-E motor.
but since VTEC-E get the best results when cruising ,is it worth having a VTEC-E or am I better of with a normal VTEC?
cheers
Old 09-04-2010, 05:28 PM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
The vtec-e engine gives you alot of low end torque, perfect for starting from a dead stop and for crawling along, if you are doing a steady 25mph on a flat road you can be in 5th gear if you are using the transmision from the vx/cx as well and your engine will be turning just under 1,000rpm.
You wouldn't get to use the lean burn part of the engine much, but the whole vtec-e is pretty impressive for an engine that was in a production car.
1994 Honda Civic D15 3-STAGE VTEC TURBO 55+ MPG FullRacePhil For Sale 30 03-03-2015 07:05 AM
VX swap running bad. Carwhisperer EcoModding Central 0 09-03-2010 03:44 PM
Honda Lean Burn D15B 3-stage VTEC rkcarguy For Sale 12 01-20-2010 01:42 PM
A Running Log website similar to EcoModder? 1337 Off-Topic Tech 2 03-12-2009 04:28 AM
Woohoo, this place is worth more than CleanMPG dcb The Lounge 4 10-16-2008 10:24 AM
