Old 10-01-2009, 09:56 PM   #1 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 31.38 mpg (US)
Tune-up suggestions?
Hey, since I have got some money I have got new ceramic break pads for the front brakes, 2 new rotors for the fronts, just recently got new spark plugs and just now got new spark plug wires... I'm not exactly sure what I need to look at next, I know my air filter is decent... What other simple things should I look at? how much will that stuff cost to repair? Thanks for any help
Old 10-01-2009, 11:32 PM   #2 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Fuel Filter (if equipped) and PCV valve would not hurt.
GeoMetroforum.com - got mpg?
Old 10-02-2009, 01:14 AM   #3 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Not that it's worth that much, but the PCV valve is cleanable, and you can get away with just soaking it in some gasoline, so you don't have to pay the $3 for a new one.
Did you get the brakes w/ the lifetime warranty? If not, I'm sorry...
Old 10-02-2009, 07:29 AM   #4 (permalink)
McTimson's Avatar
Maverick - '22 Ford Maverick XLT
90 day: 40.93 mpg (US)
If your engine has one, replace the distributor cap and rotor. Clean up your battery terminals, and check all your fluids.
Check the condition of your accessory belts also, and make sure they're still at the proper tension.
Old 10-02-2009, 10:29 PM   #5 (permalink)
Cycling more to drive les
White 'rolla - '05 Toyota Corolla LE
90 day: 44.39 mpg (US)
Send a message via AIM to Chalupa102
Not sure if u have already done it, but if not, clean the MAF sensor. U may already know this, but if it's dirty, it can cause poor fuel economy due to an incorrect AFR.
Corolla aeromods thread:
http://ecomodder.com/forum/showthrea...ead-11210.html
Old 10-03-2009, 09:42 AM   #6 (permalink)
Driving the TurboWeasel
Throw in a bottle of Techron Concentrate with your next fillup. It'll clean out your injectors to atomize the fuel more completely.
2012 Chevrolet Cruze Eco 6MT
Old 10-03-2009, 10:33 AM   #7 (permalink)
When you do that, fill up with Shell V-Power, first... then you'll have V-Tech in y0 gas, d00d!!! :P
ceramic breaks, spark plugs, tune-up, wires
TUNE IN TO NPR RIGHT NOW! Science Friday Big3 Bailout and Electric cars bennelson EcoModding Central 3 11-21-2008 02:35 PM
90 CRX HF.. is $160-180 a fair price for a tune up dylanu EcoModding Central 12 10-11-2008 12:36 PM
Suggestions on how I can improve my MPG on my commute?? regor Hypermiling / EcoDriver's Ed 4 06-09-2008 02:03 AM
Local commute suggestions thebrad General Efficiency Discussion 51 05-20-2008 09:49 AM
Commute Route - Suggestions Nerys Hypermiling / EcoDriver's Ed 12 05-08-2008 04:59 PM
