Old 01-07-2017, 03:48 PM   #1 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Replacing Battery With Super Capacitors
Instead of cluttering another thread I thought that it would be wise to start a fresh one.
Basically I saw this video and started thinking:
Would replacing lead acid battery with super capacitors have any effect on fuel economy? The alternator would not spend so much time charging your battery. Because the lead acid battery drains itself and requires the alternator to work to recharge it. The capacitors will also drain but they can be recharged even with flashlight batteries (to give you a couple of cranks).
One could wire a very small lead acid battery which would provide a few weeks time between uses if not every day commute. This would be the equivalent of having a lithium ion battery pack. Lightweight, can deliver as many amps but does not have as many Ah.
Pros:
Lighter (probably no gains what so ever).
Can deliver high amps
May be longer lasting than a lead acid battery
Cons:
Untested technology
Has only sufficient charge for a couple of cranks
My main question is, will it confuse the newer battery charging algorithms on the newer cars.
Old 01-07-2017, 04:20 PM   #2 (permalink)
90 day: 57.12 mpg (US)
Actually, this 3 year old thread starts off with the same Youtube video:
http://ecomodder.com/forum/showthrea...ery-27994.html
And then it got redirected to the supercapacitor main thread:
http://ecomodder.com/forum/showthrea...ent-27936.html
so maybe we better close this one and use http://ecomodder.com/forum/showthrea...ent-27936.html instead?
Thanks.
The Following 2 Users Say Thank You to RedDevil For This Useful Post:
MetroMPG (01-07-2017), teoman (01-07-2017)
Old 01-07-2017, 04:21 PM   #3 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Oh dear,
must have missed that. Sorry!
Can I nuke this thread or do the mods have to do it?
Old 01-07-2017, 04:46 PM   #4 (permalink)
No problem. I'm intrigued by supercaps too. A little extra attention never hurts
You can flag your post with the red triangle on the left if you like.
teoman (01-07-2017)
Old 01-07-2017, 07:07 PM   #5 (permalink)
90 day: 51.82 mpg (US)
teoman - saw your request to nuke this thread. I'm going to leave it (but lock it) because RedDevil's links will be useful if anyone searches using a specific query that's close to your thread title.
RedDevil (01-08-2017)
