Old 08-24-2018, 02:55 PM   #11 (permalink)
Lurking Eco-wall-o-texter
To calculate, you can find equations in googleable papers on hybrid power-split transmissions, or look up torque summing drives.
Do note that automotive differentials are not meant for continuous significant speed differential. They have only thrust washers - flat bushings - for the spider and side gears.
You might be able to creatively misuse some planetary gearsets, or rob a mechanical skid-steer loader to get a combining drive.
Apologies for terseness, home from work with something, and about out of think.
Old 08-25-2018, 12:22 AM   #12 (permalink)
Originally Posted by seifrob View Post
Or like ZIL 135, one engine transmission combo for each side, no interconnection between wheels, but road.
While this is great to operate on loose terrain, where the effect of an open differential is not so desirable, a similar approach in a road vehicle able to operate at higher speeds would require some way to emulate the presence of a differential, and then the clutch system similar to those 2-wheel tiller tractors seems to be the easiest approach.
Old 08-25-2018, 12:30 AM   #13 (permalink)
Yes, I would probably have to create something similar to a differential, but with proper bearings.
Old 08-25-2018, 12:37 AM   #14 (permalink)
To get back to my original question:
Name:	Two In One Out.JPG
Old 08-25-2018, 01:18 AM   #15 (permalink)
Wikipedia seems to indicate an averaging of the ratios. If that were so, I'd have 19 different ratios, though, some are so close as make the shift useless.
1/1 13.990
1/2 11.765
1/3 10.720
1/4 10.065
1/5 9.625
2/2 9.540
2/3 8.495
2/4 7.840
3/3 7.450
2/5 7.400
1/locked 6.995
3/4 6.795
3/5 6.355
4/5 5.700
5/5 5.260
2/locked 4.770
3/locked 3.725
4/locked 3.070
5/locked 2.630
Old 08-25-2018, 01:32 AM   #16 (permalink)
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
I think a CVT type transmission, like a hydraulic CVT, would make more sense. If I were to make a two engine vehicle, I'd make one that would run near peak efficiency while cruising at highway speed, and the other for use only during acceleration. That way I wouldn't have a large engine running far from peak efficiency just so it can have enough power to accelerate quickly. But I don't thing that would work with your differential idea.
Old 08-25-2018, 03:56 AM   #17 (permalink)
Not sure if I understood correctly now. But anyway, maybe you should try to consider the final output as the arithmetic mean between the different gears.
Old 08-25-2018, 04:40 AM   #18 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
You seem to be forgetting that the same torque has to applied to both half-shafts. It makes no sense for the engines to use different gears, if the higher gear gives enough torque, then both engines could just be in the higher gear.
Old 08-25-2018, 05:33 AM   #19 (permalink)
Yeah, it's just a crazy mind exercise.nobody needs that many gears.
In fact, knocking the too close ratios and the shifts requiring back shifts on one transmission leaves 10 up shifts, including two ultra high cruising ratios:
Easiest
Shift
Patern
1/1 13.990
1/2 11.765
------------(Not Used) 1/3 10.720
------------(Not Used) 1/4 10.065
------------(Not Used) 1/5 9.625
2/2 9.540
2/3 8.495
------------(Not Used) 2/4 7.840
3/3 7.450
------------(Not Used) 2/5 7.400
------------(Not Used) 1/locked 6.995
3/4 6.795
3/5 6.355
------------(Not Used) 4/4 5.25
4/5 5.700
------------(Not Used) 5/5 5.260
------------(Not Used) 2/locked 4.770
------------(Not Used) 3/locked 3.725
4/locked 3.070
5/locked 2.630
Old 08-25-2018, 11:17 AM   #20 (permalink)
Just have to come up with a durable continuous use differential design.
l/1/
