Old 01-22-2014, 06:41 AM   #1 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Minicars fall short for small overlap frontal crash protection (IIHS)
Only 1 minicar out of 11 tested achieves an acceptable rating in the Insurance Institute for Highway Safety's small overlap front crash test, making these tiny vehicles the worst performing group of any evaluated so far.
IIHS News Release
2nd generation Honda Fit is one of the worst.
The Following 3 Users Say Thank You to wdb For This Useful Post:
jeff88 (01-22-2014), MetroMPG (01-22-2014), pgfpro (01-25-2014)
Old 01-22-2014, 07:33 AM   #2 (permalink)
90 day: 49.01 mpg (US)
That is a very specific kind of collision, hitting a hard and straight edged wall at the perimeter of the car.
Which may happen if you hit a house, square pillar or shipping container or such.
In collisions with other cars the forces get distributed differently, it may yield a different result. In all likelyhood it will get pushed sideways somewhat reducing the structural damage.
It would be relatively easy to adapt for these kind of collisions, for instance by strengthening the corners as to divert the impact over a wider front section.
However that may have a negative impact on the ability to handle other types of collisions.
If this kind of collision does not occur very often, testing for it may force car manufacturers to build cars that are less safe in a general perspective.
Collision testing must be a mix of all kinds of collisions, to avoid the risk that car manufacturers build cars specifically designed to handle just the tested collisions well and fail miserably in other aspects.
Collisions with fixed objects are a bit suspect, as the presence of those is a road safety issue. You should not encounter those on a safely built road.
There will always be other road users so collision testing with other vehicles is a must.
Cobb (01-22-2014)
Old 01-22-2014, 09:42 AM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Note: the small overlap test is relatively new, and many models tested were designed before the test was introduced.
You can bet the next generation models (e.g. 2015 Fit) will do better.
Old 01-22-2014, 11:07 AM   #4 (permalink)
How does the group do on collision avoidance tests?
The Following 7 Users Say Thank You to Frank Lee For This Useful Post:
Cobb (01-22-2014), jamesqf (01-23-2014), NeilBlanchard (01-22-2014), niky (01-22-2014), P-hack (01-22-2014), pgfpro (01-25-2014), wdb (01-23-2014)
Old 01-22-2014, 11:07 AM   #5 (permalink)
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
These tests are to show what happens in an offset, head on collision I believe.
Old 01-22-2014, 11:09 AM   #6 (permalink)
CFECO
CFECO's Avatar
90 day: 29 mpg (US)
Depends, were the drivers Texting?
Old 01-22-2014, 11:42 AM   #7 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Sad to see how my Fit did. STill, it's worth noting that it's the oldest car in the list, and the top-scoring Chevy is the newest. I expect the new Fit to do well like the recently introduced Civic and Accord have.
I believe it's intended to mimic when you run off the road and nearly but not quite miss a tree or post. I can see that happening.
Old 01-22-2014, 01:20 PM   #8 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Smaller cars are also much easier to avoid hitting solid objects and other vehicles while larger, wider vehicles have a much smaller margin of error.
The Following 2 Users Say Thank You to Ryland For This Useful Post:
jamesqf (01-22-2014), P-hack (01-22-2014)
Old 01-22-2014, 02:22 PM   #9 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
Seriously, that is at least half the missing story here. A slight offset crash on a SUV is a complete miss in a small car. Plus less mass can change directions easier.
The Following User Says Thank You to P-hack For This Useful Post:
Old 01-22-2014, 02:40 PM   #10 (permalink)
My parents had an Accord (1977) and a Mercury Montego. The day they dodged a head on (other driver drunk) they chose the Accord. I wonder if they would be here 30 years later if they had chose the Montego. The drunk was in a Cadillac, caught shortly later.
92 and 87 now thanks to that 1977 Accord that I rebuilt with 13k miles.
regards
mech
