Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 10-06-2010, 05:58 PM   #21 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
How many teeth do you recommend on the fixed gear?
Do you think that this is a good bike?
I would probably want a freewheel, because I am a pedal and coast kind of guy.
Nissan Versa Aeromods
Old 10-06-2010, 06:16 PM   #22 (permalink)
OregonOutback - '01 Subaru Outback
90 day: 27.97 mpg (US)
Looks like a fine bike. It wouldn't be the lightest around with all steel parts, but it would be fun still. Gearing depends a lot on the person and how many hills or wind you'll encounter. I would start with a lower gear ratio and move higher if you feel comfortable. With that bike, the 46x16 seems high, but maybe you are pretty strong already?? A 17t freewheel would lower it if you wanted.
New Cycling website: www.mybikespot.com
Old 10-06-2010, 08:02 PM   #23 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
If you're looking for a cheap single-speed simulator, shift your bike into a certain gear and leave it there for a week. Let us know how you like it.
Old 10-06-2010, 08:14 PM   #24 (permalink)
Are you against singlespeeds for any particular reason?
This won't give you the foggiest idea of riding a singlespeed because it will only give you the negatives of riding one without any of the positives.
Old 10-06-2010, 09:11 PM   #25 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
Not busting your chops but what are the positives??
"Judge a person by their questions rather than their answers."
Old 10-06-2010, 10:00 PM   #26 (permalink)
Haha ok. The benefits are a more direct drivetrain that do away with inefficiencies. If you put 200 calories into a fixed/singlespeed that is properly geared, you will travel further than if you put that energy into a similarly equipped geared bike. If you don't believe me, try it. I would think this would be the type of forum that would enjoy this concept.
Old 10-06-2010, 10:21 PM   #27 (permalink)
ECO-Evolution
Lazarus's Avatar
I'm not convinced. I just don't think that unless you are on flat ground with no wind you would use less energy over a given course compared to a geared bike. Maybe Bicycle Bob will chime in.
I will say that I think racing or riding (not quite so much) a SS is one great learning tool that can really help a ecodriver to maximize their efforts. It's all about momentum. Any acceleration takes a big hit on energy required to get back up to optimum cadence. So you learn to read the terrain, not scrub speed in turns and ride with load up hills. So much of it transfers to the car.
Old 10-06-2010, 10:21 PM   #28 (permalink)
This page is written by a fairly well-known bike guru:
Singlespeed Bicycle Conversions by Sheldon Brown
He does say a multi-speed bike may be better for going the furthest with the least amount of effort. I would say perceived effort isn't necessarily the same as power output... but it probably doesn't matter.
He does say:
"You can really feel the difference! A singlespeed is noticeably quicker and easier to pedal than a multispeed bike in the same gain ratio."
Anyways, this has been a fun discussion. A good bike is a great way to get around. Any bike that allows you to not use a car is a good one in my opinion
Old 11-08-2010, 11:25 PM   #29 (permalink)
The 3.0 ratio seems about right and I have tried it on a internal gear 3 spd. Try to reduce rotating mass first. Aluminum rims and lighter tires, crank and gears etc. The trick is to find the bike and fit that works best with your body, riding skills, and terrain. Every bike will benefit immensely from reduced wind drag through a light weight fairing system.
Old 11-10-2010, 12:55 AM   #30 (permalink)
Why not carry this ultimate efficiency quest to its logical extreme? Remove one wheel, and the associated weight & friction. Then you can get rid of the chain, and large parts of the frame, and wind up with this: Unicycle - Wikipedia, the free encyclopedia
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Announcing a complete solution to mapping engine efficiency kubark42 Instrumentation 80 01-14-2011 09:36 PM
The Easy Leg: Vehicle Efficiency natefish Off-Topic Tech 17 05-19-2010 04:52 PM
The ultimate efficiency 4-passenger car Ernie Rogers General Efficiency Discussion 25 05-16-2009 07:27 AM
Getting more efficiency out of a ZX2. Small list of mods and driving tips for it. koihoshi EcoModding Central 9 07-20-2008 04:26 AM
