Old 11-02-2010, 04:47 PM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Ultralight 15" wheels for Citroën/Peugeot owners
Looking for a second set of wheels I came across lightweight wheels for Citroën's C5, serial number 5401.Q8. They look like steelies, but are supposedly alloys, and weigh only 4 kg each. Size: 15" 6J, 4x108 screw pattern, ET18.
From the info I've found, the first batch of wheels could dangerously crack, but this was fixed with new screwholes and special screws.
I'd love to get a set of those on the car, but I'm not sure how to discern the "bad" batch from the fixed wheels. I also don't know whether special screws will fit my hubs. Plus the ET18 offset means they will stick out 9mm compared to mine (ET27). This may make my rear skirts obsolete.
Old 11-03-2010, 11:03 AM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Thread and pitch will most likely be identical if your car has the same bolt pattern. The special part is usually how the bolt seats onto the wheel.
(My Volvo also has different bolts for steel wheels, and bolts that can fit either steel or alloy wheels.)
Found this on
The lightest "steels"? - 106 Rallye Register Forum
the part number is 5401.Q8 , i just bought 5 of them from citroen last week , they were £22.16 each + VAT
the wheels that originally came with the C5s were recalled , these are the wheels with the flat seats for the bolts , the replacement wheels have tapered seats and special wheel bolts , the kit of bolts is 5406.08 , and its £11.92 +VAT
Old 11-03-2010, 11:25 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
The wheels were actually that cheap originally? I wonder what they can be had for now. Seems like a great steal (wink).
Old 11-03-2010, 04:04 PM   #4 (permalink)
aero guerrilla
Piwoslaw's Avatar
I saw them new on an auction recently for 150 PLN plus 60 PLN shipping ($53.50+$21.50=US$75 at today's rate) for each wheel. I've spent quite a bit on the car in the last month (and that's not the end if it), so I have to be careful when talking about investments with the Wife, but a deal like this is hard to pass up...
Old 11-03-2010, 05:53 PM   #5 (permalink)
The PRC.
Ah, the old joint account issue. I have that one too. The best approach is to make the investment and then tell her about the benefits in the afterglow of success. Thats how I handle these situations.
(When I say 'handle' I mean 'apologise')
Old 11-03-2010, 11:42 PM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
Nevertheless, sounds like quite a deal.
Old 11-19-2010, 11:58 PM   #7 (permalink)
Silver Scrapper - '02 Toyota Corolla CE
90 day: 32.64 mpg (US)
The lightest wheels I could find for my car are 9.3 lb(4.2kg) Kosei aftermarkets that cost $134 per wheel, so $75 is quite a good deal.
Old 11-21-2010, 03:04 AM   #8 (permalink)
aero guerrilla
Piwoslaw's Avatar
Update.
I've found these wheels used on various auctions, for as low as $40 each. I almost picked up two, but the trip got cancelled and I didn't want to do a 500km round trip just for them. I asked the guy who replaced my tires for the winter what he thinks, and he said that lighter wheels would be great, but I should buy only one first to see how it fits.
He also gave me a sermon about summer tires should be wider than winter, to improve grip and handling at higher speeds. He had a hard time believing that I don't do higher speeds.
Old 11-21-2010, 12:11 PM   #9 (permalink)
The PRC.
Without going too OT, what is the advantage of winter tyres vs summer ones ? I have never switched for the seasons - although last year's long snow here with near slick Yokohamas was 'fun'. I don't have a spare set of wheels or space to store them, and most tyre places here won't (at least not regularly) fit / remove /replace anything they haven't sold you.
Also what about oil ? I run the VW certified stuff (505.5 ?) which seems to have a low enough temp for anything I see in winter yet I read people here also swapping that for winter. I also have American friends who change every 3 months, I go 6 as my mileage isn't high and it fits in with a summer / winter service together with MOT (safety certificate) expiring at the end of the year.
Temps and weather here don't vary normally very much - the temp range maybe goes from 20-30 Deg C in summer to -5 in winter. And, in Scotland at least, the only noticeable difference is that the drizzle and wind gets colder
Old 11-21-2010, 12:57 PM   #10 (permalink)
Cevic - '09 Honda Civic DX-G, coupe
90 day: 39.79 mpg (US)
Grip on snow / ice is way better with winter tire. See:
Living in Quebec, Canada, I can tell you I won't ever ride a car in winter without winter tires (plus, it's illegal ). It already saved my life more than once, and saved many lives around me too (read: anyone driving a car living here.)
The oil VW recommend (5w30 synthetic) for my car fits for summer and winter; but I still change oil before and after winter. I'd rather not have to do it by -25*C
Temps around here vary from +30*C to -30*C, and first snow was two days ago
Oh, and I almost forgot. They (the tires makers ?) recommend we switch tires when the average temperature goes below 7*C. Higher temp will ''melt'' winter rubber too fast, and a lower temperature will make the summer rubber too hard to have good grip (assuming no snow/ice).
Otherwise, nice find on the light wheels ! Wish I could get some lighter wheels for my jetta...
alloy, citroen, light, peugeot, wheels
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
WTB four 4x4.5 hub Toyota wheels 14 or 15" JackMcCornack EcoModding Central 3 07-31-2010 01:52 PM
Civic VX wheels or aftermarket? travr6 EcoModding Central 8 03-07-2010 06:37 PM
New Wheels & Tires trikkonceptz Success Stories 9 11-03-2008 02:05 PM
The finest Chinese cr*p that money can buy. (wheels & tires) lyd EcoModding Central 13 09-30-2008 05:41 PM
