Old 04-01-2010, 12:56 PM   #1 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Nose ideas?
Here is one of the forum sketches of my Celebrity. The front end is pretty much square across with pretty square corners.
I am thinking about some sort of nose for it. It can bolt on to the steel bumper just like the tail supports do in the rear.
Any ideas of something that might do some good?
Winter daily driver, parked most days right now
Summer daily driver
Old 04-01-2010, 05:35 PM   #2 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 29.13 mpg (US)
IDK if this is what your looking for but it would make your front more rounded...
The grill block that goes all the way out to the front of the bumper and clear whatever you want to use to go over the light.
Name:	Celebside Fin and Extension.jpg2222.jpg
ID:	5889   Click image for larger version
Old 04-01-2010, 05:52 PM   #3 (permalink)
90 day: 34 mpg (US)
I know this is different but I was bored
Old 04-03-2010, 02:59 PM   #4 (permalink)
I would encourage you to go to the FLOW-IMAGES (brain-food) Photo-Gallery 3 and look at the Rabbit in the wind tunnel.
It has a front end very much like yours and there is no separation there,although an enormous wake,mostly responsible for it's Cd 0.42.
My 'ideal' nose added almost zero benefit to my CRX,whereas the boat-tail got me above 60-mpg.
Hucho emphasizes,that once we achieve attached flow,there is no point to keep softening.He also emphasizes that improvements are going to come from mods to the back of the car.
Old 04-03-2010, 05:00 PM   #5 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
wagon, I have something similar to the center section of post #2 on my car in the winter. I keep the upper grill blocked year round and don't really realize any difference in mpg with or without the nose. It does seem to function like a hard bra to keep my upper grill from being sandblasted to bits by winter debris. If your upper grill is blocked, I don't see what it would hurt. Somewhere I have seen a Hucho?? drawing of drag coefficients of several nose shapes and lower seems better up to a point.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 04-04-2010, 02:07 AM   #6 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
How about using two large, curved panels to give a rounder profile, and have them meet in the middle, opening like lips to adjust the cooling intake size? It could probably be done in Coroplast with some heat-forming at the sides and other careful work, leaving it with enough flex to open or shut.
Old 04-04-2010, 03:03 PM   #7 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Add a nose similar to the one I installed on my car. In addition to lowering the stagnation point for reduced drag, it also gives you space to install a driver adjustible grill block, the rounded shape directs deer up and over the top of the car, greatly reducing the amount of damage incurred in a vehicle-deer collision, and the nose also provides some additional crush space in the event of a collision with something heavier than a deer. It doesn't look like it would be that difficult to install a rounded nose over the existing bumper.
Old 04-07-2010, 12:39 PM   #8 (permalink)
wagonman76's Avatar
Team Chevy
Basjoos, would your nose work without a bellypan? I use an airdam because trying a partial bellypan before really hurt FE, the underside of the car is horrible so I do best to just keep the air out from underneath it to start with.
Summer daily driver
Old 04-07-2010, 04:29 PM   #9 (permalink)
Ecobalt's Avatar
I found a promo ad for the early Chevrolet Celebrity. The automaker noted that they made the windows "more flush" with the window/door frame to improve aerodynamics and reduce noise. So, the automaker has done some design work for you. My hunch is that blocking the grill would be a good first step. RandomFact's artwork upthread is fun.
I drove my Celebrity wagon for 140,000 miles before I donated it to charity. I recall that there was a small black airdam under the radiator. You could secure some flexible L-shaped material and build a lower airdam.
Old 04-07-2010, 04:56 PM   #10 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Basjoos' nose is designed with the tip low. The lower front end directs air up and over the car. Less air goes underneath with the nose than did without. An air dam works in the same way, it lowers the stagnation point, forcing more air over or around the vehicle.
Engine/ECU mod ideas for mileage jcantara EcoModding Central 11 04-30-2010 05:22 PM
Extra Motorcycle - Looking for Ideas rwyler EcoModding Central 1 03-03-2010 07:05 PM
Help with DIY electric system and hybrid ideas ProtractedSilence EcoModding Central 5 11-10-2009 12:32 PM
Ideas to build a green masonry home? Christ Saving@Home 30 07-07-2009 08:57 AM
jeep aero mod ideas johnpr Aerodynamics 22 08-27-2008 07:45 PM
