Old 04-03-2010, 10:13 PM   #1 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Under belly pan Q45 edited..
Replaced the front under pan with a solid sheet of choroplast.
Added material to redirect rear air.
close up of the edge of the solid material.
rear....
Old 04-03-2010, 10:30 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
mcrews -
Cool beans! I like the second from the last, where you make sure to "curl up" the leading edge of the rear to avoid a parachute effect.
Is that really coroplast or styrofoam? I was expecting to see plastic that was like cardboard :
CarloSW2
American Solar Energy Society
Old 04-04-2010, 07:32 AM   #3 (permalink)
mcrews's Avatar
Carlo,
it was at the store where I bought the choroplast. It's not styrafoam but harded, more rigid. Thd had a large scrap and I used it in the back and now the front.
Yes, the chorplast curved nicely to seal up the back area.
The Following User Says Thank You to mcrews For This Useful Post:
cfg83 (04-04-2010)
Old 04-04-2010, 10:19 AM   #4 (permalink)
Target 70mpg (UK) (58 US)
Clara - '94 Vauxhall Cavalier LS
Last 3: 51.88 mpg (US)
it looks like it might be a product called Foamex but I could be wrong (or something similar)
Old 04-06-2010, 05:29 PM   #5 (permalink)
Infiniti
I like very much what you've done and I certainly don't want to discourage your efforts,but I wanted to point out that Nissan has done enough under car aerodynamic refinement on the Infiniti that they've published advertisements showing only the underside of the car.
Bottom line ( no pun ) is that you may not see gains,as say,you'd see on a Jeep,Land Cruiser,Rover,Tahoe,Suburban,etc..
Your refinements will put you in good stead for tail modifications should you choose to pursue that in the future.Nice work!
Old 04-06-2010, 07:52 PM   #6 (permalink)
I gotta build me a bellypan! I'm contemplating either Coroplast, or aluminum flat bars & roll flashing...
Good job!
Old 04-07-2010, 01:41 AM   #7 (permalink)
mcrews's Avatar
Actually, you are right a STOCK Q45 has some nice underbody panels that seal right up to the FACTORY bumper......
however, my situation is a little different.
I am running a Full IMPUL body kit which lowers the body lines 2 inches all the way around...
creating this.....
here was my dec thread describing my results....along with a blocked grille.
http://ecomodder.com/forum/showthrea...q45-11402.html
under belly pan for 02 Q45 mcrews Aerodynamics 110 06-14-2018 01:23 AM
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Belly pan + Fan concept? meanderingthemaze Aerodynamics 13 02-08-2010 01:09 AM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
