Old 07-08-2009, 07:44 PM   #11 (permalink)
have you thought about filling in the fog light indentions?
Old 07-09-2009, 08:02 AM   #12 (permalink)
hiro256, since I use the foglight area to draw cold (ram) air for the engine, it would be not so beneficial to seal this area. Other than that, I use my fogs more than the headlights.
Old 07-09-2009, 11:07 AM   #13 (permalink)
How about fixed headlights? I saw a C5 in Houston with some nice bubble shaped fixed lamps
Old 01-06-2011, 08:14 PM   #14 (permalink)
any updates on your mods? thinking about doing a similar ones to mine.
Old 01-06-2011, 09:20 PM   #15 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
I was about to ask the same question. A friend of mine has a '99, which always gets me wondering about tweaking a Corvette.
You might look at using some .040" 5052 aluminum sheet metal where the exhaust pipes are. I have some under my engine compartment and down the belly of the truck due to the exhaust pipe running there...
you might look at the wheel cover thread also.
Old 01-07-2011, 02:08 PM   #16 (permalink)
After over 18 months of driving around with my underbody panels here a quick feedback on the parts.
Good thing is they are still on the car. Bad thing is that over the course of time some tie straps needed to be replaced since they somehow ripped apart. The rear piece is also intact and didn't suffer any direct heat damage.
Both front and rear panels though did deform slightly and lost some of their strength due to heat and gravel pounding against the surface.
I am thinking about replacing them with solid plastic sheets - using similar plastic that the OEMs use for their underbody panels.
Does anyone have any idea where to get this stuff?
BTW. The mpg gains are still existing and I could verify them when I had removed the front part temporarily.
Thanks
Alex
Old 01-07-2011, 10:03 PM   #17 (permalink)
thanks for the update, just need to find the time and materials to try it too.by any chance did it help with the dirty rear?
Corvette Z06 Wins MPG Marathon SuperTrooper General Efficiency Discussion 11 08-29-2009 08:12 AM
High-MPG Corvette Big Dave General Efficiency Discussion 49 06-16-2009 01:33 AM
C5 corvette hiro256 Aerodynamics 25 04-22-2009 04:38 PM
