03-29-2012, 01:24 PM
Coroplast Engineer
Underbody panelling & exhaust
As of now, I'm ready to start moving on with modifications on my car. I've already done an upper grill block, air dam, wheel covers and rear wheel skirts. Next, I am looking at the underside of my car. I have made all of my modifications with coroplast, and I want to continue to use it on the underside. My question is how I should handle the heat generated by the exhaust. Obviously, I don't want to melt through the coroplast, but I still want to cover the exhaust as it is aerodynamically "dirty." I have heard of people using crushed aluminum cans between the coroplast and exhaust, but will this work? What other ways could I handle this? Thanks.
Originally Posted by Tango Charlie
You know how when you buy a car, and then you start noticing how many others there are on the road? Yeah, that doesn't happen with a 1st gen Insight.
AV Build Thread
03-29-2012, 08:56 PM
Location: sw Washington (state), a little north of Vancouver
Wouldn't a layer of foil work?
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 60MPG so far 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
03-29-2012, 09:50 PM
You could use a wire mesh screen for covering the exhaust parts. Enough to dissipate the heat and somewhat still aerodynamic at higher speeds.
03-29-2012, 09:59 PM
I use crushed cans. Works great and it's free. Otherwise you might look into fiberglass insulation, or as Mr. Buck said, heat-reflecting foil.
03-29-2012, 10:39 PM
heading for 40
what about some silicone cookware. I see a lot of them in thrift shops and dollar Stores.
does my sig work now?
03-29-2012, 11:08 PM
Coroplast Engineer
Sven7, so crushed cans does work? I figured the cans might get hot and melt the plastic. I'm pretty familiar with your car thread, but I can't remember. Do you use crushed cans with your undertray, and if so, how did you attach them?
AV Build Thread
03-30-2012, 01:45 AM
I just poked holes halfway down the cans and zip tied them to the belly pan right under the muffler. No fires yet
The Following User Says Thank You to Sven7 For This Useful Post:
03-30-2012, 02:59 AM
Coroplast Engineer
Thanks, I'll have to try that.
AV Build Thread
03-30-2012, 01:52 PM
#9 (permalink)
you crush them flat or straight down like a can crusher does?
03-30-2012, 02:30 PM
#10 (permalink)
T-100 Road Warrior
I used aluminum flashing from Home Depot/Lowes to protect my Coroplast on my belly pans (engine bay and main belly). Ended up buying a big roll...20"x50'.
Dark Aero-The world's first aerodynamic single wheel boat tail!
