Old 10-09-2009, 12:12 PM   #31 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
46mpg on the way to work today, much better than the previous week. Filled up when I got to work. 42mpg, I was at 40mpg when I did this change, it improved my average by 2 We'll see how next week goes....
Old 10-10-2009, 09:43 AM   #32 (permalink)
Team ZX2
I did check my ignition advance yesterday. At 50mph and a 21TPS (just enought throttle to keep it rolling and not loose speed) the advance was 35-36. Going slightly downhill at 50mph and a 19-20TPS the advance was 39-40, which I presume is max. Idle TPS is 17. I need to test this with the line pluged back in to compare. This is quite a mystery, I did a little drive last night, I often drive this route and have never gotten better than 40mpg, last night I got 42. It definatly is working...and I'm not getting any pinging or surging that is typically associated with vacuum leaks.
Old 10-10-2009, 11:10 AM   #33 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
So if you're at max-advance, you should be making a bit more power, too, I'd presume. Except for the leaner burn, maybe. So maybe you just didn't lose any power?
I would have to wonder what would happen at this point if your knock sensor was still plugged in?! I bet that thing would be going crazy!
Old 10-10-2009, 01:54 PM   #34 (permalink)
Team ZX2
The knock sensor goes crazy no matter what It's pretty much useless on the ZX2
Old 10-15-2009, 08:36 PM   #35 (permalink)
Team ZX2
We have a winner!
P0171, Bank 1 lean, Fuel Trim Maxed Out. Nice I'm lean burning Just wish I knew the real AFR, so I could see if I was in danger, Oh well, these engines are cheap enough, LOL! Took a week for the SES to come on. I guess the computer was determined to get it right. The crazy thing is, it just seems to get better and better. Probably I'm just learning to drive it better lean. It can take a bit more throttle and not kill the mpg's and it takes more throttle to climb the hills. Also, I just did 47mpg on the way home yesterday, that's as good as I did on summer gas in 90 degree weather. Now it's winter gas and 50 some degrees. Wish I had found this in the summer. Now to get the HAI hooked up and some more aero mods and this winter may be better than summer Horray for Vacuum Leaks!
Old 10-15-2009, 10:15 PM   #36 (permalink)
We have a winner!
I can only wonder how long it was like this before you noticed it?
Old 10-15-2009, 10:47 PM   #37 (permalink)
Team ZX2
I noticed it imediatly, you might remember the orginal thread where I thought changing my pulleys gave me some great mpg gains. That's when I forgot to hook that line back up and I noticed the change on my test drive. It was a couple days later that I found the line and this journey to understand began.
Anyone got a spare wideband they wanna loan me
Old 10-15-2009, 10:48 PM   #38 (permalink)
Well, I had a UEGO, but I'm not sure where it's at...
So those pulleys netted nothing?
Old 10-16-2009, 08:48 PM   #39 (permalink)
Team ZX2
Nope, no gain from the pulleys But it is quieter now
Old 10-16-2009, 11:47 PM   #40 (permalink)
This has been driving me nuts, trying to figure out what the line to the intake duct could be for. I found this post on teamzx2:
TeamZX2.com - View Single Post - Little hose thingy?
The air pulled from the intake tube is routed through a device called a vaccuum booster/check valve. The air is drawn through a boost venturi and the vaccuum level is increased. Cool.
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 10:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
