Old 11-03-2011, 02:15 AM   #1 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Toyota/Subaru's new RWD Coupe
FR-S/BRZ Specs and options
FR-S/BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc.
Originally Posted by Japan 10-15 cycle
Drinks premium unleaded and 50L fuel tank.
Fuel consumption base model:
13 km/l
30.58 mpg
49.21 kmg
Originally Posted by Coefficient of Drag
RX-8: 0.30
CR-Z: 0.30
FR-S: 0.27*
Prius: 0.25
*Company Est.
The FE is better than a Miata, albeit barely. Curb weight might be 2700lbs stateside since we measure with a full tank vs half a tank. But the aerodynamics really surprised me. Any comments?
-Allch Chcar
Old 11-03-2011, 02:23 AM   #2 (permalink)
They'll have no trouble selling this if they can undercut the genesis coupe. I'll wait for the turbo.
Old 11-03-2011, 02:27 AM   #3 (permalink)
EtOH
No turbo mate. Check the compression ratio 12.5:1! Subaru is working on a new turbo engine for their WRX/STI but chances are slim this car will ever offer a second engine option.
Needless to say the HP guys are crying over it.
-Allch Chcar
Old 11-03-2011, 05:45 AM   #4 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Direct injection FTW!
The engine might be turbo converted(or have the CR in creased) by switching the DI part of the fuel system to ethanol tho.
Note: The mileage number is from the Japanese test, the EPA-number is likely to be significantly lower.
Old 11-03-2011, 07:31 AM   #5 (permalink)
Hubert Farnsworth's Avatar
Planet Express Ship - '94 Geo Prizm LSI
90 day: 36.57 mpg (US)
Strictly speaking its both port and direct injected using the Toyota D4S dual injection system and will switch back and forth depending on load and speed, but yes it was direct injection (and the addition of 5-8% more air mass inducted at the beginning of the cylinder charge) that allows for higher compression ratios on regular fuel without detonation, pre or post spark auto ignition, etc.
Old 11-03-2011, 01:42 PM   #6 (permalink)
Yes turbo. Its coming a year after the base model. You'll see.
