Old 03-04-2010, 12:00 AM   #41 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Any bets on whether Frank will pull easier or harder than his competition?
Same truck, and similar weights. Not super scientific but it may be the only reference given the Short [hopefully] Happy Life of Francis M.
Cheers
KB
Old 03-04-2010, 12:16 AM   #42 (permalink)
awesome cad discription video !
Old 03-04-2010, 02:12 AM   #43 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Easier. Less weight, shorter, and less frontal area, regardless of Cd, plus a more rounded front end.
Old 03-04-2010, 02:27 AM   #44 (permalink)
Can't say. Similar weight, similar frontal areas (?), as noted, more rounded isn't an automatic benefit.
Old 03-04-2010, 02:30 AM   #45 (permalink)
But it should be.
I like-a do da cha-cha.
I dunno, I was guessing on seriously limited data, so I didn't make any effort to actually make it a serious guess.
Old 03-04-2010, 02:32 AM   #46 (permalink)
Yeah, my real answer is it's too close to call I think. Given similar test conditions I'd not expect one to outperform the other. Still needs a topper.
Old 03-04-2010, 05:34 PM   #47 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I'm have my fingers crossed for the Frankentrailer. Just a WAG but judging from the photos on the website, Frankentrailer appears to have nicely tapered sides and a much narrower rear profile than the Scamp.
That said, there are a ton of variables that could throw the results off i.e.; headwinds, cold temps, rain, snow, slush. To really know would require ABABAB testing on the same day, same weather conditions with a fully warmed tow vehicle.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
KamperBob (03-04-2010)
Old 03-04-2010, 07:40 PM   #48 (permalink)
Recreation Engineer
KamperBob's Avatar
Loaded
I agree that a scientific comparison would be ideal for the learning aspects of this project. I wish that was practical but it's just not. This is my criteria for success.
  1. Safety: nothing exciting happens
  2. Protection: nothing inside the trailer is worse for wear
  3. Performance: MPGs not worse than the Scamp
We're loaded. Ready to hit the road after work tomorrow. Should be there Sat PM. Route is central MA to central IL by way of I80. If you see us wave. I wave back because I'm friendly. If Frank waves back, something is loose!
Cheers
KB
The Following User Says Thank You to KamperBob For This Useful Post:
aerohead (03-06-2010)
Old 03-08-2010, 12:53 PM   #49 (permalink)
Recreation Engineer
KamperBob's Avatar
Quick update: the trip was uneventful. Some info on Frank's "project" page.
FrankenHauler
Cheers
KB
aerohead (03-09-2010)
