Old 04-02-2010, 12:55 AM   #21 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
speed density system
This did bring to mind a question -- This car has no MAF sensor, so it does not sense air flow directly. How does the ECU interpret a restricted air intake? For instance, if (heaven forbid) I mash the pedal to the floor, the throttle position sensor goes wide open, but the intake tube, being slightly smaller than the TB opening, is not allowing quite as much flow as would normally occur under stock conditions.
Does the ECU take into account engine vacuum
and other factors to compensate for the reduced air flow? This will never come into play in normal driving on this car, but I was curious about it.
__________________"...
yes
it uses a MAP sensor as the primary load sensor
MAP = Manifold absolute pressure
MAP = ambient barometric pressure - intake manifold vacuum
the system is in fuel control so a slightly restricted air intake
has about zero affect on anything
except at WOT
as per EPA and iatn
Old 04-02-2010, 01:58 AM   #22 (permalink)
Saturn Driver
Nels's Avatar
Peanut - '96 Saturn SL
90 day: 37.27 mpg (US)
Originally Posted by Chris D. View Post
hmmmm lets see the melted piping... bad motor mount?
Mounts are fine
Nels
Manitowoc WI
1996 Saturn SL, 5-sp manual
2011 Fiesta SFE sedan, 6-sp dual dry clutch Powershift transmission
Old 04-02-2010, 02:09 AM   #23 (permalink)
Saturn Driver
Nels's Avatar
except at WOT
as per EPA and iatn
Thanks. That's what I was hoping.
Nels
Manitowoc WI
Old 04-07-2012, 09:16 PM   #24 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by JoJotheTireMan View Post
That is exactly how mine is setup, hooked to manifold vacuum. Low vacuum equals CAI and high vacuum equals WAI/HAI. A3 (1993-1999) VW 2.0L air box has dual inlets and a vacuum controlled flapper to switch back and forth.
My 91 Jetta had one of those, but the cold air intake was only 1 inch diameter. I tore that whole thing out and made it a 4 inch diameter feed directly behind the headlight and I actually gained 2 mpg. But it didn't run so well in the winter; stumbled routinely...like I had water in the gas.
[edit] maybe I should have made the flapper bigger instead...
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Hot Air intake vs. Cold Air... why or why not? Blister General Efficiency Discussion 3 10-09-2008 10:01 AM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 10:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
A New 'Take' On Hot Air Intakes Funny EcoModding Central 18 04-11-2008 07:23 PM
