Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 02-08-2015, 09:41 PM   #11 (permalink)
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
My metro can lite cruise @ 22.4-1+, that's as high as my wide band will read. It starts missing at higher ratios.
Old 02-08-2015, 11:04 PM   #12 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
how do you change the AF ratio?
Old 02-09-2015, 12:43 AM   #13 (permalink)
iveyjh's Avatar
I use an apexi AFC(air fuel controller) and run open loop all the time.
The Following User Says Thank You to iveyjh For This Useful Post:
ECONORAM (02-13-2015)
Old 02-09-2015, 01:14 AM   #14 (permalink)
dirtydave's Avatar
Duct Tape Aero Crew
Team Chevy
I have noticed my car gets better MPG the more the engine is off. Pushing my foot down heavy gaining the speed I need and cutting the engine off as much a possible gets the best MPG. changing the AF ratio would help me I think.
The Following User Says Thank You to dirtydave For This Useful Post:
deejaaa (04-16-2015)
Old 02-09-2015, 01:48 AM   #15 (permalink)
dirtydave's Avatar
Duct Tape Aero Crew
Team Chevy
AFC NEO - Electronics
$495????
Old 02-09-2015, 01:50 AM   #16 (permalink)
dirtydave's Avatar
Duct Tape Aero Crew
Team Chevy
AFC Neo, Fuel Management
The AFC Neo marks the newest edition to the world famous Super AFC line of piggy back fuel controllers. Building upon the powerful AFC Neo, the AFC NEO has taken piggy back style fuel control to a new level. The AFC Neo boasts an incredible 16 points of user definable fuel correction. VTEC control has also been incorporated for Honda/Acura applications. A complete monitor mode is also available to keep the driver/tuner informed of critical engine data, such as: RPM, throttle, battery voltage, correction %, air flow%, pressure (kpa), and karman sensors.
The AFC Neo is the industry standard for sub computer fuel control. The AFC Neo is designed to fine tune and "squeeze" power out of existing engine setups by allowing the user to modify the fuel curve with precision accuracy. Since the act of simply bolting on performance products does not make horsepower, the AFC allows the user to calibrate the fuel system in accordance with performance upgrades as they are installed. The AFC modifies the air flow meter/ pressure sensor signal voltage going to the factory ECU (Engine Control Unit) to change the amount of fuel injected. The AFC utilizes a Color FED (Field Emission Display) to display critical data in three different modes.
The AFC, while not completely universal, comes pre-programmed with 28 of the most commonly used air flow meter (hotwire type), 21 pressure sensor (map sensor type), 8 air flow meter (flap type) sensor maps. By setting the AFC to one of these programs, the user is able to adjust injected fuel amounts by +/- 50%. 8 or 16 user defined RPM adjustment points allow maximum tuning in 500 rpm increments. Fuel can also be adjusted for part and full throttle situations.
The Deceleration Air Flow Correction cures erratic idle problems for Hot Wire vehicles equipped with an open atmosphere blow off valve. The AFC can also display an incredible amount of data including: Air Flow Capacity (Hotwire and Flap Type only), Engine RPM, Throttle Position, Pressure Sensor voltage, Karman Frequency and Air Flow Meter Correction.
The AFC Neo displays data in three different modes: Numerical, Analog, and Graph. Numerical Mode allows the user to monitor up to four different parameters in numbers and also shows peak hold values on demand. The Analog Mode displays up to two values in an easy to read meter style display. The Multi Mode displays up to two parameters in digital and one parameter in analog. Peak Hold is also included in this function. The Graph mode offers real time graph plotting with a Ghost map trace feature built in. The graph can replay movement up to 60 seconds.
Old 02-09-2015, 11:14 AM   #17 (permalink)
iveyjh's Avatar
Look on Craigs List or Ebay for an Apexi Safc or a Vafc. I find them there for under $100.
Old 02-09-2015, 11:25 AM   #18 (permalink)
For $500 you can get an E-Manage that will do ignition timing, as well... or a Unichip Q... or an AEM... or...
I think there's also Split-Second, though I don't know about compatibility or price.
Old 02-09-2015, 12:27 PM   #19 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
The reason I'm going with this setup is because I've always believed that cars are running way to rich! I've thought for the last 5-10 years that if the fuel requires 14.7-1 a/f ratio at atmospheric pressure then it souls only need about 147-1 at a 10-1 compression ratio do to the reduction in the fuel molecules distance apart. At 10-1 compression ratio and 147-1 a/f ratio the fuel molecules are about as close as they would be at atmospheric pressure. I was able to mess around with my scooter yesterday for about 4-5 hours on 2 ounces of Coleman camping fuel, not sure of its fuel economy yet because I had no way to control it will on it.
Old 02-09-2015, 02:44 PM   #20 (permalink)
Dark Egg - '12 VW Touraeg
Cars are not running way to rich for economy, they are doing it because of government regulations.
