Old 11-14-2010, 03:51 AM   #51 (permalink)
Originally Posted by bestclimb View Post
how about 4 clutched v twins. The clutches could be designed to slip just a little bit with electronic pins that engage when the rotational difference is reduced enough not to shear them or they could be electronically controlled and the computer could closely match RPM then let the pins slip in negating the need for a clutch. The pins and holes could be located so as to reduce harmonic vibration...or what ever. Just begs for straight pipes out the hood, with flappers on them so you know how many pairs are running or nice mufflers under the rig with a set of lights on the dash if noise ordinances get you down.
Yup, exactly the strategy I've contemplated... well, you really, REALLY lost me when you added the straight pipe part.
Old 11-14-2010, 03:57 AM   #52 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
I was mostly kidding with the straight pipes, tough to stream line and would be obnoxiously loud, not to mention you could make wild gains over straight pipes with an appropriately tuned exhaust. Trouble I see with it is that the timing of the power stroke on a 4 cyl would be different from a 6 cyl would be different from an 8 cyl That could be overcome by having more than one set of holes for the pins to drop into.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 11-14-2010, 04:11 AM   #53 (permalink)
I'd take a cue from the marvelous (kidding) Cadillac V8-6-4 and not even fool around with more than 2 modes. IIRC, many of the complaints with the 8-6-4 were with roughness in the 6 cyl mode.
Old 11-14-2010, 04:13 AM   #54 (permalink)
Smeghead
well that would be more simple wouldn't it.
Old 11-14-2010, 04:15 AM   #55 (permalink)
Yup. I'm interested in doing a 2-2.
Old 11-14-2010, 10:42 AM   #56 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by mechman600 View Post
LOL...you will make millions!
Seriously, yank the 4.7 boat anchor and install a small turbocharged four banger.
Okay, give me the money and I'll do it.
Plus, thanks to the magic of variable geometry turbochargers, turbo lag is eliminated and torque curves are flat as a pancake all the way down to 'just above idle' RPMs. Hmm...seems like a magical recipe for ecommodding to me!
IIRC, VNTs don't do well with gasoline engines. It had something to do with their higher exhaust temperatures frying the exhaust vanes and/or mechanisms of VNTs... The only successful gasoline VNT I know of was the Dodge Shelby CSX, and that turbo was poorly matched to its engine.
Oh, and don't forget to attempt to freeze your slushbox. Torque converters ruin most economy attempts.
Again: Give me the money and I'll do it.
Otherwise, I'll pursue this on my own time, with my own dime. One of the goals of this project is to recoup, within 30 fillups, the money spent on a particular truck modification. For instance, the aerocap I spent $75 to make would pay for itself within 14 fill-ups, or 7 weeks of driving. Another goal is to not reduce the existing functionality of the truck. Again, the aerocap I made comes off in all of 30 seconds, and I can then haul heavy and/or large things.
So don't mention engine/tranny swaps or any other obviously costly measures. The goal is to save money, not piss it down the drain in an attempt to increase my gas mileage.
Old 11-16-2010, 02:03 PM   #57 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
It's as easy a buying a total loss car from an insurance yard for $1000.
Are not most new turboed cars VNT/VGTs? VW/Audi 2.0T, Ford Ecoboost, The coming Volt 1.4T? I assumed they would be, because I'm a diesel guy and that's mostly what I see. I know Porsche 911 turbos use them for sure.
Old 11-16-2010, 08:02 PM   #58 (permalink)
MPGuino Supporter
t vago's Avatar
And your point is what, exactly? Do I drive a totalled car to and from work for fuel economy gains, or do I spend many more thousands of dollars retrofitting the engine from this totalled car into my Dakota?
I seem to remember saying that I was going to spend as much money as I could recoup within 30 fillups in my truck. Somehow, that just doesn't seem possible with either option presented above.
Diesel exhaust tends to be cooler than a comparable gasoline engine exhaust, coming right out of the head. This is why there has only been one production gasoline car with a VNT. The production Volt is going to use a naturally aspirated E85 1.4L 4-banger, not a turbo of any sort.
Old 11-16-2010, 09:31 PM   #59 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
Are the parts that you pull out not marketable? I think you could sell them, for doll hairs, or what ever the currency of the day is, and use that for what you want to get.
Just checked, ebay tranny both manual and auto are equal in cost. Its like pure profit
engine you have $1400
engine you might want (pt turbo?) $1095
or, different truck that gets better mpg.
Old 11-17-2010, 05:21 AM   #60 (permalink)
mechman600's Avatar
With an entire donor car, all you need is a welder, cutting torch, soldering gun, heat shrink, and lots of imagination. Oh, and time. Not much extra money required.
Or sell the truck and get a smaller vehicle, unless of course you need a truck. Making a V8 Dakota get good fuel economy will be like squeezing cool-aid out of a watermelon. My V6 Escape is exactly the same way. Brutal on fuel even when I'm on my best driving behavior.
Thoughts on Direct Injection (New Camaro, Hyundai Sonata) RH77 The Lounge 3 05-27-2010 09:24 PM
thermal thoughts owly Introductions 8 01-27-2010 11:29 PM
Honda is developing a variable compression automobile engine: MPG up 7.4% MetroMPG EcoModding Central 22 04-23-2009 10:59 PM
Variable reluctance VSS mossman OpenGauge / MPGuino FE computer 12 03-30-2009 07:42 AM
MetroMPG.com mailbag: is lowest RPM really best for max MPG with big displacement? MetroMPG Hypermiling / EcoDriver's Ed 20 01-06-2008 01:00 PM
