Old 07-07-2008, 01:36 AM   #1 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
veggie oil weight does matter
today i took the Chevy Colorado to go get a hundred plus gallons of vegetable oil.. the best i was able to pull off was 33.5 MPG usually i can break 35 mpg for a round trip.. weight surly matters .. I had the two 55 gallon barrels tucked up next to the cab witch should have helped areo-dynamically.. the barrels weigh about 300 pounds each i was hauling about 600 lbs of raw oil and my MPG surly was hit by the added weight.
Old 07-07-2008, 06:45 PM   #2 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
What are you hauling Veggie oil for?
In town, I'll bet it (weight) matters a good bit
On the highway I'd say that the tires would be the primary determining factor . . .
So you are estimating 6 lbs/ gallon? I was thinking it was more like 7~8 lbs/ gallon. Maybe I can haul 100+ gallons with the golf after all.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 07-08-2008, 02:36 PM   #3 (permalink)
Water weighs 8.33 pounds per gallon, and most of the things I've read use that same 8 pounds per gallon weight.
I think the OP had 600# of oil in two 55 gallon containers, but they weren't full of 55 gallons each (that would have been 440 pounds each, or 880 total).
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
VW pickup for conversion to electric or veggie oil? bennelson Fossil Fuel Free 16 02-12-2009 06:13 AM
My odd ball veggie oil hypermiling ebacherville Hypermiling / EcoDriver's Ed 5 05-16-2008 01:28 AM
Good Veggie Oil conversion!?!? bennelson EcoModding Central 12 02-14-2008 10:09 PM
Oil weight question: 0w30 or 5w20? MetroMPG EcoModding Central 4 11-25-2007 08:57 PM
