Old 07-29-2008, 07:17 PM   #1 (permalink)
mush3gan's Avatar
vent instead of A/C
hey if i roll up my windows and turn off the A/C but instead also open the vent / turn on the fan.. does that waste gas also? should i not have anything on at all?
Old 07-29-2008, 07:21 PM   #2 (permalink)
Hi,
It uses some, but not nearly as much as running the A/C. Crack the windows and run the fan.
Old 07-29-2008, 08:53 PM   #3 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
With just the vent open in the panel position, I think in most cars this uses no power at all unless you have the blower fan on.
GeoMetroforum.com - got mpg?
Old 07-29-2008, 09:13 PM   #4 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
The lack of proper diffusers in the ventilation system means that air can get around a car easier than through it. For maximum economy with some cooling, I'd leave the vents open, the vent fan off, and run an accessory fan to blow on my body. In a hot, dry area, I'd add an occasional water mist.
Old 07-29-2008, 09:31 PM   #5 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
I find vents more or less worthless, other than on those odd days in the spring and fall when it's not that warm out, but the sun makes the inside of a car hot anyway.
As I suggested in the post about pulsing AC, driving with the passenger-side windows both open an inch or two in a 4 door sedan or wagon creates a nice breeze without massive amounts of drag, especially at higher speeds.
Old 07-29-2008, 09:54 PM   #6 (permalink)
My Saturn SC1 seems to have lost about 3 mpg since A/C season started.
Typically my interior air temp after being parked outside all day in the sun with windows closed (white car with light tan interior) is 130-135F.
Gas is gonna have to be $10/gallon before I scuttle the A/C.
Old 07-29-2008, 10:12 PM   #7 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
Sun blocking devices work wonders. Generic accordian for the front; static and fabric shades for the side windows and even rigged up wire hangers and pillowcases that hang off the handles above the doors for extra protection. It may not look pretty but getting in a car that is only 100 versus one that is 130 is good enough for me.
whokilledthejams is right with just using the windows ajar. That bit of air circulation moving through the cabin will drop the interior temp dramatically. If humidity is an issue, try a portable dehumidifier (passive or plug-in) -- the cabin is small enough that most should work.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-30-2008, 11:26 AM   #8 (permalink)
mush3gan's Avatar
ok, so i will go with the inch or so crack in the windows.
what if i turn on the fan, but no A/C? is that using up a lot of power?
Old 07-30-2008, 12:42 PM   #9 (permalink)
Hiya,
The fan uses only a little bit of power; relative to the A/C.
Old 07-30-2008, 12:50 PM   #10 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Hiya,
Generally, but unfortunately not on my elantra. As soon as I turn the ventilation on, with or without A/C, at idle GPH goes up 0.1. There is only a 0.02 GPH difference between fan level 1 and 4.
Cracking my window and the opposite rear window an inch is the best solution at speed.
www.HyperKilometreur.com - Quand chaque goutte compte...
Electric A/c conversion lovemysan EcoModding Central 15 08-28-2010 08:48 AM
Insulating cold a/c lines? CHEGAI EcoModding Central 18 06-30-2010 12:34 PM
A/C Recirc trikkonceptz EcoModding Central 5 07-31-2008 09:49 AM
Which front Vent to block? freeyellow2000 Aerodynamics 2 07-09-2008 09:21 PM
It's not just the A/C tasdrouille General Efficiency Discussion 4 04-17-2008 11:57 PM
