07-10-2019, 10:53 PM
Down the Rabbit Hole with Eviation's Alice
Wowsers.
Check out the skin radiators at https://youtu.be/W0DHhiwvatQ?t=104 and consider the architectural advantage of an ME-262 shark-like shape to the fuselage for headroom in a small cabin.
Props positioned to accelerate the three wake-producing areas, with [high frequency] torque vectoring because landing can be tricky. At https://youtu.be/W0DHhiwvatQ?t=145 the rendering shows two- and three-bladed props.
So what do you think? How will they look with advertising all over them?
.Necessity is the mother of invention, but simplicity is it's favorite aunt --Amish proverb
07-11-2019, 10:02 AM
Somebody needs to call bill lear, they stole his plane.
I think I will be optimistic/ skeptical until type certified and produced.
07-11-2019, 11:58 AM
The Lear Jet had two turbojets on the fuselage and a T-tail. ....and a round fuselage. I'm more reminded of Scaled Composites.
07-12-2019, 10:37 AM
LEAR FAN. Two intakes on fuselage, I believe a pair PT-6 turbo shaft inside, "Y" tail. The black engineering prototype was across the street from my old job.
Maybe your right, does have that scaled composites look.
07-15-2019, 09:53 AM
Pretty amazing plane!
07-15-2019, 10:41 AM
Thalmaturge
I mean, kind of? But also not really?
SC definitely does the non-tubular fuselage thing a lot though... nothing like this either, really.
/arc-anglerfish-arc2-prod-mco.s3.amazonaws.com/public/RBVTY6IZAJGTXCLGXNI4APDZRQ.jpg)
07-15-2019, 02:34 PM
https://en.wikipedia.org/wiki/Learjet#Timeline
I looked at the link I provided, there was a major redesign a one point. Isn't there some disadvantage to the V-tail? Maybe compared to Y- or T-tail?
There's airframe and there's power plant. Those skin radiators need a lot of wetted area.
07-15-2019, 09:36 PM
A V tail has less drag than a conventional tail, because there are fewer intersecting surfaces. A T tail is slightly lower drag, I think, because the intersections are farther apart? But the structural simplicity of the V tail gives it a bit of a weight advantage, maybe?
I am surprised a bit by the slim wings, and slender wing section.
The wing tip motor pods would seem to alleviate the vortex drag, I think?
07-15-2019, 09:47 PM
#9 (permalink)
Thalmaturge
I wouldn't be. If you're looking for maximum efficiency but not necessarily maximum speed.
Or high altitude and maximizing dwell time on not much fuel.
07-15-2019, 10:18 PM
#10 (permalink)
https://duckduckgo.com/?q=aircraft+V-tail+disadvantage
Apparently less interference drag but more wetted area required. And more complicated control linkages.
It looks like all the air sees is high-efficiency airfoils and propellers sucking any detached airflow for lunch.
