Old 12-04-2008, 10:31 AM   #1 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Straight Ethanol conversion info
I ran across some information on converting an old car to run off straight ethanol. It's for a carburated system, but lots of good information there, and the whole thing is free on the web.
Not sure how it would apply to more modern fuel-injected systems, but take a look:
Convert Your Car To Alcohol
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 12-05-2008, 01:52 PM   #2 (permalink)
EcoModdingNewby
Send a message via AIM to dogbreath
See [url=http://www.change2E85.com]URL] unit that allows non flex fuel cars to run ethanol; have had one of these on my 2008 Prius since I bought car- works great.
Last edited by dogbreath; 12-05-2008 at 01:54 PM.. Reason: Link showed up incorrectly
Old 12-06-2008, 11:07 AM   #3 (permalink)
EcoModdingNewby
This software must not like Safari;
here's the link:
E85 Conversion Kits Change2E85.com
Old 12-11-2008, 10:23 AM   #4 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
I did take a look at than unit, and called and talked to the local distributor.
The main thing it does is simply holds the injectors open longer.
Simply switching to larger fuel injectors would do the same thing, other than the device would still allow you to use gasoline as well.
To do a really proper conversion, and get good fuel economy the car's ECU needs some information coming back to it, which is appropriate for ethanol.
That may mean modifying the signal out of the oxygen sensor or mass air flow. I am still reading up on it and trying to figure out what would work.
My YouTube Videos
The Ethanol Scam: Are ethanol advocates giving slanted mpg numbers? Ptero Fossil Fuel Free 15 04-22-2010 09:58 AM
[Article] Better Fuel Economy with Ethanol? SVOboy General Efficiency Discussion 62 04-02-2010 11:31 AM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Ethanol kills grain food market WaxyChicken The Lounge 14 12-11-2008 10:07 PM
Ethanol Conversion? '93 Corolla Fossil Fuel Free 4 09-02-2008 05:42 PM
