Old 03-04-2009, 02:11 AM   #11 (permalink)
In hypermiler central
[SOLD] Highway Warrior - '00 Mazda Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Mazda Miata Touring
90 day: 30.93 mpg (US)
Send a message via AIM to 1337
I have Michelin Harmony 185/65R14 tires on the front of my Mazda. It had a broken belt in one of the front tires when I bought it, so I needed to make a quick choice in replacement tires.
I considered the above mentioned sumitomos and the Potenza RE92s that the Insight uses. However, based on reviews from Consumer Reports, some independent rolling resistance data, and Ecomodder forums, I chose the Harmonies.
Customer reviews on tirerack.com and elsewhere are dissatisfied with the Potenzas for sacrificing lots of handling for little rolling resistance gain. I'm very happy with my Harmonies, which I have inflated to the sidewall max of 44psi.
Old 11-05-2010, 03:27 PM   #12 (permalink)
VX Padawan
VX du Slog - '94 Honda Civic VX
Originally Posted by backsidesnap View Post
I have been looking around to buy a set of sumitomo htr t4's for a long time. And it seemed that tirerack was the only place to find them. then I found onlinetires.com and they have them at 39 each for the stock vx size. and the shipping is ten bucks less. Just ordered them tonight, but im excited to have lrr's in the stock size!
Any update on the Sumitomo HTR T4s? I'm torn between the 175/70 Kumho Eco Solus (marketed as a LRR tire) and the 165/70 Sumitomo HTR T4 (that has the reputation as a LRR tire.)
Slight advantage to the 165/70 for being the stock size, since I dont' have to do any match, and it retains the same (intended) ratios as the stock VX. But Kumho *says* their tires are LRR, so it has to be true, right?!
EDIT: Also saw that the Potenza RE92 is available in 165/65-13... are these popular?
Diesel- and Hybrid-Powered Vehicles Can Provide More Societal Benefits than Gas-Power SVOboy General Efficiency Discussion 12 04-29-2017 08:03 AM
Civic VX & CX Spark Plug Gap flydude1221 EcoModding Central 9 07-01-2012 05:08 PM
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 09:38 AM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 02:52 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
