Old 09-25-2012, 10:02 PM   #11 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
Okay thanks a lot, I appreciate the input. 35 mpg would be a step down for me... That's not happening! This is exactly why you read BEFORE you buy! I am now better at spotting VX's and d15z1's (Po7 cylinder head).
Old 09-25-2012, 11:37 PM   #12 (permalink)
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
That's a V-Tec setup, same as the one in my '94 Si. Like Hondaguy72 says, it's kinda neat but not a real FE setup. Keep your eyes peeled for a real VX or HF, the gearing and the lean burn will be where it's at.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
Old 09-26-2012, 02:06 AM   #13 (permalink)
Originally Posted by 2000neon View Post
I am totally new to hondas, and im searching but having a tough time understanding this mini me swap.
A bit of history:
People used to take the B18 engine from the Integra LS (a 1.8 liter non-VTEC making ~130 HP) and put the VTEC head from a B16 or B18C on it. This was a less expensive way to make a 1.8 liter motor with VTEC which made quite a bit of power, and was easier to come by than a B18C or a US-spec B16 motor. It was dubbed an "LS-VTEC swap".
Someone then realized that you could take a D-series bottom end (in the 88-91 CRX world I was interested in, it was usually a D16A6 "Si" motor) and put a D16Z6 or D16Y8 head on it. That would give you a bit more compression on your 1.6 liter D-series motor, and VTEC. This was after the Austin Powers movies were out, and it got called the "Mini-Me LS-VTEC swap".
I don't know which head is on there, but it appears to be either the Z6 or Y8 one due to the position of the spark plugs. Someone would have to read the engine code (on a boss in the front of the motor near where the trans bolts up) to see if it was a 1.5 ("D15") or a 1.6 ("D16") liter motor.
-soD
The Following 2 Users Say Thank You to some_other_dave For This Useful Post:
2000neon (09-26-2012), Ryland (09-26-2012)
Old 09-26-2012, 06:39 PM   #14 (permalink)
2000neon's Avatar
Thanks a lot! I have been reading about VX's,but am still very new to hondas in general.
