Old 04-24-2010, 02:13 PM   #11 (permalink)
- - '10 Toyota Prius III w/Navi
Hi All,
Those are quite interesting videos! That vortex generator just drives the air into the floor dramatically. You know they gotta be generating allot of drag to do that.
The issue with such techniques is tuning them to get the air to just deflect lightly, and curve away from the roadway and go parallel with it. Rather than as was seen in the video. And do that with a minimum of vortex generator. Otherwise the drag reduced by eliminating the tail tumble of the air, will just be overcome by the drag of the vortex generator.
Streamlining is a much more reliable method for those without the windtunel and force gauges needed to tune up vortex generators to the specific vehicle application.
I found some downloads on that web page. In his own report from 2004 he reports no VG's resulted in less drage (40 degree boattail).
http://www.vortaflow.com/consulting/...unt%20body.pdf
And that he was going to investigate smaller VG's.
Old 04-24-2010, 05:55 PM   #12 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Yes. If you read the guy's paper on his website, he admits that the drag is actually greater with the vortex generators than without them.
Old 04-25-2010, 12:24 AM   #13 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
Vortex generators are far more effective in reducing rear lift, unless you have them along the sides of a large, square rear end, like a semi.
In Reason we Trust
Old 04-25-2010, 10:50 PM   #14 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
Laack,GOOGLE the Mercedes above in the title box and see what they did.
I see they extended the decklid with the giant wing...but are you saying the wing helped with drag reduction?
Name:	Mercedes 190E 2.5 EVO II small.jpg
Old 04-26-2010, 06:54 PM   #15 (permalink)
wing
Tygen,what caught my eye,was both the fairing at the top of the backlight which softens the curvature off the roof allowing 'clean' air to strike the wing,both above and below,and the boot extension,which runs straight back as far as the end of the bumper.
This is kind of a permutation of the Merkur XR4Ti bi-wing spoiler,where they look to manage the separated flow both high and low.
If the wing was just symmetrical,with no induced lift,It could serve as a re-attachment point and work to
'sculpt' the wake a bit.
I found an article on the 1988 Holden Commodore VL SS Group ASV by Tom Walkinshaw who created 18-aero add-ons for the car,dropping Cd from 0.43,to 0.32.
He extended a rear spoiler as far as the bumper and raised it about 7.5-inches ( 187.5 mm ) at the trailing edge.He also extended the C-pillars back to it to create the 'birdbath on the boot' also used on the Mustang GT.
The extreme spoiler on Mike Murillo's Pro-Stock '93 Mustang notchback,is as long as the trunklid itself,projecting straight back with zero upsweep.
And for protection to pedestrians,you just put a couple of SIMPSON drag chutes under it,sticking out a little bit.
If that doesn't 'man-it-up' enough,then I don't know what will!
Wake field of pickup KamperBob Aerodynamics 28 07-14-2011 01:52 PM
GTI seat in my Geo and more wt reduction ATaylorRacing EcoModding Central 3 03-15-2009 11:52 PM
2008 Prius wake Cd Aerodynamics 15 01-08-2009 05:43 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 10:45 PM
Prius wake turbulence Otto Aerodynamics 13 04-21-2008 11:44 AM
