Old 01-13-2009, 09:52 AM   #1 (permalink)
Uncle Jam
GasGuage's Avatar
Lil' Red - '97 Chevy S-10 ext 2WD LS
90 day: 31.02 mpg (US)
S-10 gears
I was just wondering what gear ratio's S-10 owners are running in there 3rd members. My '97 w/2.2 5sp has 411's out back. I hooked up a SG 2 since I don't have a tach, & seen at 55mph, I running around 2400rpm.. That seems a little high. I figured the truck came out with low gears to compensate for the 4cyl, but I'm beginning to wonder. I guess I shouldn't complain seeing the mpg I'm getting, but it would be nice to see it under 2000rpm. If it only came out with a 6sp.
Old 01-13-2009, 11:11 AM   #2 (permalink)
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Oldsmobile Intrigue GX
Last 3: 25.94 mpg (US)
Dad has the 3.73s in his (ZR2). I've seen everything from 3.08s to 4.11s. There may be even a wider range than that.
That must be a fairly tall overdrive 5th, to get 2400 @ 55 with 4.11s. I've seen 1:1 4-speeds with shorter tires running right at 3 grand @ 55...
...not conducive to good fuel mileage!
Here is a place that you could look around and maybe find something...
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
Old 01-13-2009, 01:15 PM   #3 (permalink)
Red
Red's Avatar
Highest you could go is a set of 2.41s, but you'd probably be lugging it. There is a lot of choices for that 10 bolt
GM / GMC / Chevrolet S10 Blazer Rear Differentials GM 7.5 Rings & Pinions Auto Parts: YG GM7.5-273, YG GM7.5-308, YG GM7.5-323, YG GM7.5-323T, YG GM7.5-342, YG GM7.5-342T, YG GM7.5-373, YG GM7.5-373T, YG GM7.5-411, YG GM7.5-411T, YG GM7.5-430, YG GM7
Old 01-16-2009, 02:09 AM   #4 (permalink)
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
i hhve 29 inch tall tires 3.58's and a .85 fifth in my 98 taco ( it is my lowest geared vechile)
at 55mph it runs a 1950rpm.
most new 6 speeds are over rated they give u an extra gear in between 3rd and 4th and about the same top gear as they 5 speed counter part.
Old 01-16-2009, 08:23 AM   #5 (permalink)
Uncle Jam
GasGuage's Avatar
My tires are 29" too. I'm not sure what the 5th gear ratio is. I guess I'm pretty close on the rpm's. I'd still like it under 2000, but I'm stuck with what I have.
Old 01-16-2009, 12:51 PM   #6 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I have no idea what the gearing in my rear differential are!
I have the most plain/stock S10 ever - 1995 2.2l 5-speed.
I am planning on swapping my engine for a 2.4l Mercedes diesel. When I do that, I will need to talk to the local hot-rod guy who knows rear axels. He should be able to help me change the gearing to take advantage of diesel's torque to maximize fuel economy.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-16-2009, 07:46 PM   #7 (permalink)
work truck s-10 - '99 chevorlet S 10
90 day: 23.64 mpg (US)
Heidis VW - '97 Volkswagon Jetta GLS
90 day: 20.54 mpg (US)
most extended cab s-10's with automatics have 4.10 rear ends in them, the ones with manual transmissions have 3.73's
Old 01-16-2009, 08:49 PM   #8 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 40.29 mpg (US)
See now I'm confused, as I thought Chevy followed a strict pattern with their S-10 diff's...
4.11 for 2.2 + auto
3.73 for 2.2 + 5spd
3.43(.42? .45?) for 4.3 + auto
3.07(.10? .08?) for 4.3 + 5spd
That's what I saw, somewhere. Maybe in my service manual, although that was 98-03.
Old 01-16-2009, 09:13 PM   #9 (permalink)
3.42 and 3.21 from the little bit i know, i wish i could find the s-10 forum that i used to belong to.
lost it when my lap top crashed
Old 01-16-2009, 11:47 PM   #10 (permalink)
Intrigued's Avatar
4.11 for 2.2 + auto
3.73 for 2.2 + 5spd
In the old days it was 3.42 and 3.08. Nowadays??? Who knows... The site Red linked to a few posts back gives the whole range, I believe...
At the dealership I worked at, the salesmen liked to show their prowess in filling in the little squares that varied from the default on the order blank - after they had asked whether you were looking for mileage or were going to pull a trailer, of course...
I was just one of the mechanics, but once in a while they would use me as a guinea pig, to order in a special hot-rod version of one rig or another. Then they would let me do the pre-delivery on it, so at least I would get to drive the thing!!! Had a Trans Am scare the snot out of me once...
