Go Back   EcoModder Forum > EcoModding > EcoModder Blog Discussion
Old 11-05-2008, 09:50 AM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
9 Tips to Winterize Your Car EcoModder Style
With winter fast approaching we’ll be seeing a lot more of this sort of thing.* We’ll also see our MPG drop off. This is normal. You will get lower mileage in winter, its just physics. However, there are a few things you can do to fight it. Here is my winterization list [...]
More...
Old 11-05-2008, 09:56 AM   #2 (permalink)
Very good article if I do say so myself!
Thanks for the extra tips guys.
Old 11-05-2008, 02:35 PM   #3 (permalink)
90 day: 51.82 mpg (US)
Good list! I can tell you this article will probably see a fair amount of traffic over time - the block heater posts on MetroMPG.com are seasonal favourites. Lots of people Google these topics year after year.
Old 11-05-2008, 04:14 PM   #4 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
Thanks a lot
I will not need snow tires, as I can see snow only once every 2 years...
I finished my full grill block lately. Now the temperature on the dash board start to climb later, but reaches its steady temperature faster. No overheat
I will lower the tire pressure from 51 (max sidewall) back to 46, as max sidewall is too uncomfortable with the roads I have to use in my city.
I changed the wipers this week-end and used an anti-rain product : I was feeling like at wrap 9 in Star-Trek today
Finally my only interrogation is the EBH (engine block heater)...
Is one of you living in a 220V world have found a 220V EBH ? I can see only 110V EBH on Internet.
In fact I don't know if it can be profitable, economically or ecologically, as night temperatures are going under 0°C only 30 times by year in here. Currently with 5-9°C (41-48°F) I do feel the MPG drop in spite of the full grill block installed : 15% less FE compared to 20°C (68°F).
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 11-05-2008, 10:04 PM   #5 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
Denis, good question about the 5-9C range - I'm sure it would help some, but how long to make the cost of the heater and the electricity pay off? I don't know. I believe Metro did it in much colder temps, up North there you know...
How about mentioning tarping the windshield? Saves lots of time idling and time out scraping in the cold. Several products are available that are specific for covering the car before you go in at night and you tuck it into the front doors. I've used a tarp in the past, and now that I'm a full on ecomodder, I'm going to put it up every night and at work whenever there's the slightest chance of precip.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 11-06-2008, 07:34 AM   #6 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
The block heater is worth it even in 10C + temps. Not only does it reduces fuel consumption, but it also reduces start up emissions by up to 80%.
REDUCED COLD START EMISSIONS THROUGH USE OF ELECTRIC ENGINE HEATERS
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 11-06-2008, 04:38 PM   #7 (permalink)
X-Frenchy: very
groar's Avatar
Diesel
Very interesting doc thanks a lot
Damn, I want my EBH now !!! Dear Santa Claus...
On a French forum I was directed to webasto products (see Retrofit warmth with a parking heater from Webasto - www.parkingheater.com for North America). These heaters are using the car's gasoline to heat both the engine and the car's internal. They have a timer or a HF remote.
The pro is that you don't need an electric cable running from your house to your car : I park the car I'm using at the other side of the road...
The cons they have to be installed by professionals and there is none at less than 150 miles from home.
bbjsw10 already talked about them here : http://ecomodder.com/forum/showthrea...ater-5639.html.
Denis.
Old 11-07-2008, 08:02 PM   #8 (permalink)
This has nothing to do with FE, but it's also a good idea to carry a set of jumper cables or a battery booster in the trunk. A battery can go out anytime, but colder temperatures will put more strain on the battery making it more likely to fail. If you're in an area that gets lots of snow it can also be beneficial to carry a bag of oil absorbent or kitty litter in the trunk too to put under the drive wheels to help you get traction if you get stuck in the snow. Also a blanket or a few extra layers of clothes in the trunk are a good idea in case you have trouble on the road you can stay warm until help arrives.
Old 11-07-2008, 08:24 PM   #9 (permalink)
gascort's Avatar
As well as dressing for the weather; prepare for cold in and out of your car and you won't waste fuel idling it to get it warm in the morning.
Old 11-07-2008, 10:06 PM   #10 (permalink)
MarzyPan - '95 Honda Civic 2000 Si Running Gear
Well, we could do like some of the very wise Insight owners do...
Put a coat on your engine!
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
How to Winterize Your Car EcoModder Style Daox EcoModding Central 45 10-28-2018 11:12 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Alt Car Expo Los Angeles 2008 cfg83 Events & Meet-ups 2 10-14-2008 06:21 PM
Getting more efficiency out of a ZX2. Small list of mods and driving tips for it. koihoshi EcoModding Central 9 07-20-2008 04:26 AM
